20 Most Recent Fuji FinePix F810 Digital Camera Questions & Answers
If your OS is Win7 64 bit, then incompatibility must be occur because Windows XP use 32bit Operating System and driver software usually only special for each OS (x32 or x64). About upgrading the software, how will you upgrade while you can't even install the basic software in your PC ? The choice you have is find another driver that compatible with your OS, you can search via Google, and I hope you are lucky enough to get it available or even free to download.
If you still want to upgrade, then the Windows7 is the one to be upgraded so you can use XP Mode system. You must have Windows 7 Professional, Enterprise, or Ultimate to run Windows XP Mode. You can visit microsoft.com for details.
Hope this help and be kind to rate please.
(^_^)
Fuji FinePix... | Answered on Jan 26, 2016
hi your camera is kind of getting old but it is still great. some people really like it. personally I like also. however, fuji finepix f810 has little problem like yours due to delicate design. on your flash problem could has two sequence check. first is flash circuit defective or flash tube defective. second is main pcb doesn't work properly with flash function. your local repair shop would charge around $75 to 185. Fuji camera usually charge more than other brand. I am sorry that you know. Good luck with you and best regard.
Fuji FinePix... | Answered on May 22, 2011
Consider NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as the free program Picasa ( http://picasa.google.com ).
Fuji FinePix... | Answered on Apr 05, 2011
You can download driver here for free select and click what type of operating system did you use. The driver that i can provide has compatible to all unit enumerated at the lower part of the site. Use the site below to download and get your driver.
http://www.fujifilm.com/products/digital/download/01/index.html#storage
Fuji FinePix... | Answered on Jan 30, 2010
Use a card reader instead of your camera.
Fuji FinePix... | Answered on Dec 10, 2009
About the HS10 autofocus problem, I discovered the cause and solution. It is a problem of camera design, and is caused by three screws securing the CCD sensor. These screws are not properly secured and the vibration eventually dropping.
In two cameras with the same defect, the screws were loose. These screws adjust the sensor position relative to the lens and the sensor is loose when out of position not allowing proper focus.
The solution is to disassemble the camera and secure the screws.
These screws can not be too tight they need to be adjusted to position the CCD sensor correctly. The camera is difficult to dismantle because several wires are soldered.
Care must be taken to discharge the capacitor of the flash, this may cause an electric shock and burn the camera board.
Those who want to try the repair, follow the link to the service manual.
http://elektrotanya.com/fujifilm_finepix_hs10_hs11_sm.pdf/download.html
Milton Maenishi
Fuji FinePix... | Answered on Jan 05, 2019
Many occasions LCD on camera display never fails but back light fails unless physical damage to LCD screen. Hold a torch to display when camera is on you will see faint(black and white) image means LCD is ok but back light is failed, it's replaceable but needs little skill to replace. Or replace full Screen with backlight. This is easy. Just remove back cover, remove display by loosening flex lock, put back new display carefully lock it holding flex with one finger. Please do not touch display flex contacts.
Fuji FinePix... | Answered on Dec 21, 2018
Fuji FinePix F810 Digital Camera Logo
17 questions posted
Top Fuji Cameras Experts
Ekse
Azam Ali
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
fuji finepix f810 flash wont
  • Cameras
