enter the bios using password - go to security page and remove password by entering current password then press enter 2x - save changes to bios then exit.The password is now removed.
For unknown bios you will need to take it to a Toshiba service center or search for bios removal proceedures available for your model.This video may help.Cheers
Remove BIOS PASSWORD Toshiba Satelitte 110 149
Check to make sure you have the location settings correct in your computer as different locations around the world use different keyboard layouts. I.E. US keyboard layout is different the Great Britain layout.
If you are comfortable with editing the key registry, then you can open the registry (regedit) and here is the key registry location:
Keyboard settings:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout
Hi ,
Please follow the below steps
-start menu
-control panel
-language
-add a language
-select language English
-Open Button
-Select the English region you want
-Add Button
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
Joseph was using AI Chat GPT4 to answer questions and they are deleted because they are just guesses by an AI Bot and not specifically targeted to the OP question.
Disconnect from the mains. Remove the battery. Press and hold the On button for 2 full minutes, timed. This will perform a very low level power reset for your power disconnect.
It isn't the codes for the remote that matter, it is the television that you want to operate.
HOWEVER, this particular remote is custom made for one Toshiba device only!
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D.
If all in order and it still doesn't boot, try a system disc in the cd rom.
Hard disk security passwords are typically impossible to find or bypass without the right password.If the Toshiba memory is asking you for a password, kindly check If the laptop arrived with any manuals, they may contain the password or instructions on how to reset or retrieve it. the other option If a user's password is forgotten, several hard drive manufacturers offer master passwords that can be used to open a disk.
Try the Reset on page 100 of the manual for 5000 series
Initialize Telephone Settings
This function resets all Programming Mode option settings to their default setting.
1. Press 3+6+9+Hold (simultaneously).
2. Press Mode soft key.
3. Press Msg button.
4. Press Hold.
5. Press Vol 'Up' button.
6. Press Msg
7. Press Hold
8. Go off-hook, then on-hook to exit the program mode
https://www.compuvoip.com/documents/ug-dp5000.pdf
If your Toshiba Strata CHSU40A3 phone system is not displaying anything and there is no dial tone, there could be a few reasons for this issue. Here are some troubleshooting steps you can try:
Check the power source: Make sure the phone system is plugged into a functioning power outlet and the power adapter is working correctly. You may also want to try plugging it into a different outlet to see if that helps.
Check the connections: Make sure all the cables and cords are connected properly. If the phone is connected to a network, check the network cables as well.
Reset the phone: Try resetting the phone system by unplugging it from the power source and plugging it back in after a minute. This will help to clear any issues with the phone system.
Check for any damage: Inspect the phone system for any physical damage, such as cracks or breaks in the casing or any loose components. If you find any damage, the phone system may need to be repaired or replaced.
If none of these troubleshooting steps work, you may need to contact a professional to diagnose and repair the issue with your Toshiba Strata CHSU40A3 phone system.
More commonly called 'control alt delete' or the 'three finger salute' it has two purposes. On a computer that is running, it brings up Task Manager and other instant settings like Switch User, or log Out. On a computer that is frozen, unresponsive, it does a hard rest and forces the computer to reboot.
