20 Most Recent
NEC VERSA S3300 LAPTOP LCD SCREEN 13.3" WXGA GLOSSY CCFL (SUBSTITUTE PART NO.) (22099252337) Questions & Answers
Cd rom in windows 7 not working
click start right click on computer select properties top left pane device manager scroll to dvd / cd drives expand right to update driver software hope this helps
Cd rom not working
check connections inside the machine. if its been knocked the cables can come a bit loose
Hi, Can you please xplain
Hi
Switch on the your laptop and wait few second to boot the windows. after that you have a access to all inside part to use. if you need to know the configuration of your laptop follow the instruction.
- Right the my computer and and select the properties and you get the information about installed operating system and computer configuration.
- if you need Full information about to install hardware then right click the my computer and select the manage option and then select Device manager there you find the complete detail of install part in your laptop
If my solution make you happy then give me four thumb
Cheer
Hi, my screen in my laptop got 3 black hole can
This model can fix with your laptop model.
http://cgi.ebay.com/13-3-WXGA-GLOSSY-LED-LCD-B133EW06V-0-HW-1A-FW-1-/260776278475?pt=LH_DefaultDomain_0&hash=item3cb77a39cb
What software or cords do I need to get/run in order to get files to transfer to/from the NEC Mobilepro 770, or even get internet?
The NEC Mobilepro 770 is a legacy device that was released in the early 2000s and uses Windows CE as its operating system. Since the device is no longer supported, it may be challenging to find software and drivers that are compatible with modern operating systems like Windows 10. Here are some steps you can take to transfer files and connect to the internet:
- Get the necessary cables: You'll need a USB cable to connect the Mobilepro 770 to your Windows 10 PC. The cable should have a USB Type-A connector on one end and a mini-USB connector on the other.
- Install ActiveSync: ActiveSync is software that allows you to synchronize files between your Mobilepro 770 and your PC. Unfortunately, ActiveSync is no longer available for download from Microsoft, but you may be able to find an archived version of the software on the internet. Install ActiveSync on your Windows 10 PC and connect your Mobilepro 770 to your PC using the USB cable. If the device is recognized, you should be able to transfer files between the two devices.
- Connect to the internet: The Mobilepro 770 has a built-in Ethernet port that you can use to connect to a wired network. To connect to the internet, you'll need an Ethernet cable and a wired network connection. Plug one end of the Ethernet cable into the Mobilepro 770's Ethernet port and the other end into your router or modem. You should be able to browse the internet using the Mobilepro 770's built-in web browser.
- Install additional software: The Mobilepro 770 comes with a basic set of software, but you may want to install additional software to make the device more useful. You can download and install software from the internet, but make sure it's compatible with Windows CE and the Mobilepro 770.
Keep in mind that the Mobilepro 770 is a legacy device, and its performance and capabilities may be limited compared to modern devices. It's also possible that some of the software and drivers you need may no longer be available or supported.
NEC Versa LX Screen will not come on
NEC Versa LX Screen
no model told screen, a monitor is it"?
the 1998 PC that? has no change at all to run
zero.
Pentium II (p2) relic,
no modern OS run on it
the coin cell battery and huge battery are toasted.
hdd is bad.
it has zero value now, and to fix it will be costly .
the CCFL back lamps are dead.
what is there to like, sure free in a garage sale.
zero value. ,try moving from 1998 to 2010 to gain a future.
I can not play movies
Hi..
AMR (Adaptive Multi Rate) is common audio file format for mobile devices like mobile phones, laptops, portable recorders.. etc.
in fact totem movie player can't play any amr files (files encoded in amr codec) by itself. Totem Player depends on Gstreamer libs, which haves necessary media handling components .
from your post its not clear that whether your totem can't play movie files from the very beginning or just you can not play movies recently.
your totem player may lacks Gstreamer library files or somehow your Gstreamer libs got corrupted recently.
Reinstalling Gstreamer Library file may help you.
you can find
latest source version of Gstreamer on this page (more detailed download of Gstreamer can be found on
http://openports.se/multimedia/gstreamer-0.10 )
