20 Most Recent Emerson EWC20D3 20 in. TV/DVD Combo Questions & Answers
http://www.walmart.com/ip/Emerson-19-Class-LCD-720p-60Hz-DVD-Combo-HDTV-LD190EM2/16775698
Emerson EWC20D3... | Answered on Aug 31, 2014
In the old days that meant that your "flyback transformer" went bad and needed to be replaced.
Now a days it might be cheaper to just buy a new TV set - especially if it's over ten years old. Give it to Goodwill and see if one of their workers can fix it for resale to lower income folks..
Emerson EWC20D3... | Answered on Mar 10, 2014
Try going menu or setting and hit th reset buttom
Emerson EWC20D3... | Answered on Dec 02, 2013
Check the remote control for its infrared emission first. Check it with fresh batteries. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you check the site in Timeslide option, which can be selected from the dropdown list at the top left side of the display window, it will make search easy. Detailed description about how to check and repair a remote control is given in detail by one among the posts.
Emerson EWC20D3... | Answered on Apr 23, 2013
What happens in this case is a small transformer or the high voltage transformer vibrate hard enough to make that sound--not loose or bad but can cause the vibration.
I have seen in customer's homes where it was loud enough to chase cats right out of the room even in a large room.
Two ways to deal with this----with the set apart locate the part by ear or even probing with a plastic tool---when you press close to it, the sound will diminish or go away.
Believe it or not (in our shop) once located we use a hot glue gun to take the sound away---
usually if very loud it is the high voltage transformer on the main TV board (see photo of a typical one) not on the black part but on the iron like (it is a different material) core that looks like a U bolt.
it can irritate but poses no danger.
Emerson EWC20D3... | Answered on Mar 28, 2012
you will not be able to do all you want with out remote on these types of units
you should just call or write to Emerson and get a replacement from them
it will be easier than the headaches you will have trying to get a replacement that will do all the functions the original did because none of them do
good luck
Emerson EWC20D3... | Answered on Mar 13, 2011
Attempt changing the option by using the menu button on the tv (changing it manually).
Emerson EWC20D3... | Answered on Jan 25, 2011
Try website Remotes.com to buy an original very close to the original remote.
Emerson EWC20D3... | Answered on Jan 21, 2011
This problem can't solved without the remote.Because the remote the only one have a SAP button on it.Try website like Remotes.com to buy an exact remote to the original remote.
Emerson EWC20D3... | Answered on Jan 13, 2011
Hello
The specifications are
Power consumption
(Maximum) : 85W
Dimensions : H:20-3/16"(513.5mm)
W:20-3/16"(512mm)
D:19-13/16"(503mm)
Weight : 49.6lbs(22.5kg)
OK.
Emerson EWC20D3... | Answered on Dec 19, 2010
Get an original remote
http://www.remotecontrolscenter.com/emerson/n0289ud.html
Emerson EWC20D3... | Answered on Sep 26, 2010
go to remote manufacturers website click support you can download manual
Emerson EWC20D3... | Answered on Feb 22, 2010
4737 it's the default password
Emerson EWC20D3... | Answered on Feb 12, 2010
Enter 4737 and the password will be cleared
Just copy and paste this link into your internet address bar in a new tab and it will take you to the user manual site:
http://www.devicemanuals.com/guide/Television/Emerson/Emerson-EWC20D3-20-TV-DVD-User-Guide-TmpJeE5ETT.html
Emerson EWC20D3... | Answered on Nov 16, 2009
Go to www.remotes.com and put in your model number. They should have what you are looking for. If not try www.encompassparts.com. Thanks
Emerson EWC20D3... | Answered on Oct 26, 2009
no. you are a child that wants to watch bad shows huh? well you are on the internet so do it here.
by the way, the "v chip" is just a basic programming in the computer so you cant actually take a chip out.
Emerson EWC20D3... | Answered on Sep 08, 2009
Emerson EWC20D3 20 in. TV/DVD Combo Logo
37 questions posted
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Televison & Video
Most Popular Question
ewc20d3 combo not respond remote
  • Televison & Video
