20 Most Recent Goodmans G-Shot 2025TFT Digital Camera Questions & Answers
Should be in the menu settings
Goodmans G-Shot... | Answered on Jun 18, 2014
Are you sure, you are using it in automatic mode? I can't find a manual, but when you were in any menu, you could have changed your camera in something you can't handle. Please look if you can put it in automatic.Perhaps it is with the mail dial, perhaps you have to go into the menu's.
Goodmans G-Shot... | Answered on May 28, 2014
Since you managed to post this question, you obviously managed to sign in to FixYa. Are you referring to something else? If so, what?
Goodmans G-Shot... | Answered on Feb 21, 2013
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Goodmans G-Shot... | Answered on Nov 20, 2012
AA batteries will be OK alternatively you can use rechargeable AA batteries.
Goodmans G-Shot... | Answered on Nov 13, 2012
you could try an external card reader which are cheap to purchace and simple to use.It just plugs in to usb port and comes with software.good luck
Goodmans G-Shot... | Answered on Mar 17, 2011
hi there connect the memory card only by card reader and then try to transfer the photos from memory card to PC. Let me know the result.
Goodmans G-Shot... | Answered on Feb 12, 2011
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Goodmans G-Shot... | Answered on Nov 27, 2010
do i need a disc to down load my photo of my goodmans gshot2025tft to my laptop
Goodmans G-Shot... | Answered on Oct 04, 2010
You could be having an incompatability issue between the camera's drivers and the version of Windows you're running. First thing to make sure of: did you turn the camera on? (some people forget). Second thing, is your cable good?
If you connect the camera to a usb port, windows should detect it right away, as another drive (look in Computer, the folder for your drives).
If you install the camera before you install the CD, it causes problems, as these people explain in this blog:
http://www.computing.net/answers/windows-xp/cant-get-digital-camera-to-install/126152.html
You might try uninstalling and reinstalling the CD, sometimes that works. Go to Control Panel, Uninstall/Reinstall, and select the camera program.
Good luck, hope this helps, and thanks for using FixYa.
Goodmans G-Shot... | Answered on Sep 10, 2010
conect the camera and turn it on. it shud work, if not try changing the cable.
Goodmans G-Shot... | Answered on Sep 05, 2010
I hope you at least have a cable to connect your camera to your computer. Connect them and turn your camera on, then see if your computer recognizes the new hardware. Then you should be able to get your pictures.
Goodmans G-Shot... | Answered on Sep 08, 2009
This camera cannot use an SD card. It uses a CompactFlash Card Type I card.
Goodmans G-Shot... | Answered on Jul 03, 2009
You can get the drivers here:
http://list.driverguide.com/list/company2581/
and
http://www.computing.net/answers/windows-xp/goodmans-2025-digital-camera-driver/124170.html
Goodmans G-Shot... | Answered on Jun 30, 2009
Goodmans G-Shot 2025TFT Digital Camera Logo
Popular Tags
34 questions posted
Top Goodmans Cameras Experts
langhi
Harrie
Tony Parsons
Tony Parsons
Are you a Goodmans Camera Expert? Answer questions, earn points and help others
View Most Popular
Goodmans Cameras
  • Goodmans Cameras
Most Popular Question
battery 39 s g shot 2025tft
  • Cameras
