20 Most Recent Vulcan GR35 Deep Fryer Questions & Answers
try to change the thermal battery the device that the pilot heats.. other wise there is a screw at the botton of the automatic valve.. try to increase the pilot so it can heat more the thermal battery! u dont have enough voltage to activate the solenoid valve so thats why ur pilot goes off
Vulcan GR35 Deep... • Answered on Jun 13, 2015
It is possible - all that need changing are the gas coupling and burner jets. However, this isn't something you can do over the net - you will need a gas engineer to come and change the coupling and jets.
Vulcan GR35 Deep... • Answered on Aug 20, 2009
You can change the tank, but it takes 2 hours or more and costs over $750 for the part. There are several other brands of equivilent fryers that you can buy new for about the same price.
Vulcan GR35 Deep... • Answered on Mar 18, 2009
The thermopile is bad.You can contact your local hobart service center for the part number.Its a cheap part and easy to put on,any questions let me know.
Vulcan GR35 Deep... • Answered on Jul 18, 2008
You can try their website: http://www.vulcanhart.com/productliterature.cfm
Vulcan GR35 Deep... • Answered on Jun 22, 2007
Vulcan Range Behind kick plate Vulcan Oven Top behind door latch Vulcan Fryers Behind door
Vulcan Kitchen... • Answered on Apr 05, 2019
forgive my answer but you need to look at the situation by standing back a bit. You have heated the fryer up, but then you load it with product that is not at 350 degrees and the fryer must now take that 10 minutes to pull it's temp + product back up to temperature. That is as if I am understanding your question
Vulcan Kitchen... • Answered on Nov 06, 2018
HI. Its Bob To fire up, you need 3 things, Air ( with oxy) fuel and source. First step, is to make shure, you have gas. Without this, you will never get no were. Second , you must purge the system to get air out of the gas line. this is done by trying to light up the system , 4 to 8 times, here the click is the valve opening and closing.... this will clear the system out of air and get the gas to the burder. this will take time, 4 to 8 tries... if you smell for any reason gas, stop, shut off the gas... This smells like rothen eggs... Gas is heavier then air, so it flows down to the lowest level. there is also sensors ,switchs on this... Read the instruction on how to purge or turn on the gas... some have to push down hold for 5 secs, then turn.. Please work safe/ bob
Vulcan Kitchen... • Answered on Jan 06, 2018
vulcan-chef is part of the email/ electrolux group of companies (hoover, simpson,westinghouse, AEG, dishlex etc)so try the service spares for email or electrolux thermostats are fairy generic for the older units so ask the spares department for a suitable replacement ask any appliance repair shop if they could point you to a supplier
Vulcan Kitchen... • Answered on Apr 30, 2016
Faulty switch or heating element replace the faulty part if possible or replace the fryer.
Vulcan Kitchen... • Answered on Mar 04, 2016
Vulcan GR35 Deep Fryer Logo
7 questions posted
Top Vulcan Kitchen Appliances - Others Experts
Paul Carew
ray gallant
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Vulcan Kitchen Appliances - Others
Most Popular Question
change from natural gas propane
  • Kitchen Appliances - Others
