20 Most Recent Haier HTF20R21 20" TV Questions & Answers
2answers
Haier HTF20R21 20" flat screen
In google search, type in the words "the word "factory on my tv", and it comes up with solution..it worked first time for me!.. Bill
3/5/2016 5:41:45 AM • Haier HTF20R21... • Answered on Mar 05, 2016
48" haier tv is only showing a blue screen when i turn on tv
I have two haier LED LCD televisions with all the screens broken. they are 39'' and 32''. I would like to ask where I can get the screens to buy in order to fix them. Thank you.
2/13/2014 1:02:02 AM • Haier HTF20R21... • Answered on Feb 13, 2014
0answers
2answers
Haier HTF20R21 Locked
I called tech support and they said to hold down the display button (the one that normally pops up the channel that you're on). I tried it and it worked even though none of the buttons got a response. It's definitely worth giving it a try!
7/16/2013 8:03:19 AM • Haier HTF20R21... • Answered on Jul 16, 2013
Need to unlock haier tv
Contact Haier for customer service---they will step you thru the process--note that this information usually in their sets is also in the owner manual--if lost that Google the model number with "manual".
4/9/2012 2:57:19 PM • Haier HTF20R21... • Answered on Apr 09, 2012
0answers
0answers
Universal remote that work?
There is a way to program the comcast universal remote to the TV. If you still have the programming instructions, use the automatic search/ program function instead of manualy entering the product code. This usually works better since some TV manufacturers sell the same TV under other product names. Good luck. Please leave positive feedback if my answer is useful. Good luck
7/22/2010 3:48:15 AM • Haier HTF20R21... • Answered on Jul 22, 2010
5answers
Remote codes
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
7/13/2010 8:58:33 PM • Haier HTF20R21... • Answered on Jul 13, 2010
2answers
Some of my comcast digital channels are muted,
It sounds as if you have accidentally turned on your secondary audio settings.
Here is how to fix it....
On your original TV remote next to the "0" key there is a button marked "sound". Press this button until the TV says stereo.
This should fix your problem.
Good Luck and please rate this solution...
3/26/2010 3:15:51 AM • Haier HTF20R21... • Answered on Mar 26, 2010
2answers
I have a 32 inch Haier TV and my comcast cable
there is an auto search method....some remotes you can hold the tv button down and then the select button simultanteously for a few seconds to make the light turn red and then proceed with codes, when you get the right code you press the select button again, the light blinks and you are done..... well with out a code its the luck of the draw..... the auto search method is similar to programming the code in....hold the tv button and the select button for a couple seconds until the tv button lights up, but instead of a code.....press the channel up button(that represents the first autosearch code), continue until the tv turns itself off and then press the select button to lock it into the remote...........if you go past the trigger point you can channel down to backtrack.... otherwise drop it in the toilet until it wont work, call the cable company and have them send out a tech with anew remote. they cant charge you for their equipment not working correctly.
trust me, i am a supervisor at a major cable company.
1/30/2010 12:37:19 AM • Haier HTF20R21... • Answered on Jan 30, 2010
Describe your comcast remote troubleshooting.
how can you up the sound when the button doesn't seem to do anything
1/15/2010 2:00:03 PM • Haier HTF20R21... • Answered on Jan 15, 2010
I have a Haier tv model#HTF20R21 it has a blue
The parental control is on in your TV,
To unlock the parental control on your TV, that has a blue screen and a red padlock on the top left hand side, hold down the display button on the remote for 10 seconds .
And once you get into TV, you can switch off the parental control by to menu using the remote and child lock...
PLease leave me comment, if you need further assistance
RNj VINODKUMAR
11/8/2009 4:55:22 PM • Haier HTF20R21... • Answered on Nov 08, 2009
Hi, The parental control is on
You cannot unlock the unit without an original remote.
11/8/2009 4:06:39 AM • Haier HTF20R21... • Answered on Nov 08, 2009
What if I have a
The universal remote will have to be programed to the set,if the remote is new,it should come with the list of brands,and how to program the remote.
11/7/2009 8:21:59 PM • Haier HTF20R21... • Answered on Nov 07, 2009
One for all code for haier air conditioner
it depends upon the model, when you buy the remote there's a list of the unit that you may used into it. and also indicates there the code, just follow the instruction
7/31/2009 1:22:13 PM • Haier HTF20R21... • Answered on Jul 31, 2009
Haier HTF20R21 20" TV Logo
36 questions posted
Top Haier Televison & Video Experts
Paul Bade
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Haier Televison & Video
Most Popular Question
some comcast digital channels muted
  • Televison & Video
