20 Most Recent Haier HTN13R12S 13" TV Questions & Answers
3answers
Remoe code for haier tv model tdc1314s
I found the 3 digit code for my Haier tv by auto search it was 226.
11/24/2021 6:21:32 PM • Haier HTN13R12S... • Answered on Nov 24, 2021
0answers
0answers
Tv comes on once with retrace line and shutsdown
The video output card has loose solderings on it. Check and resolder all the suspected solder terminals. This board can be located at the neck of the picture tube, will be directly plugged on to it.
1/24/2013 4:17:22 AM • Haier HTN13R12S... • Answered on Jan 24, 2013
0answers
I need code or codes
from the Comcast remote manual, Haier code is not listed. So I got the below Haier code(s) from another source. Since the Haier is not listed on the Comcast manual, I won't be guaranteeing you 100% that the codes below are going to work.
Also note that the code needed might be a five digit code, in that case, add one (1) in front of the four digit codes below as a prefix. Try each and every one of the below codes.
Haier codes: 0081, 0216, 0217, 0157
I wish you good luck.
4/21/2010 9:07:23 PM • Haier HTN13R12S... • Answered on Apr 21, 2010
My tv has been blocked and it asks for a password
try 0000 that is if you did'nt put one in your self
7/13/2009 7:29:04 PM • Haier HTN13R12S... • Answered on Jul 13, 2009
2answers
13 inch Haier TV
Plug it into a power strip and turn off the power strip as well as the TV. I've been told that newer TVs are always "on" - standby mode- and someone probably has a device somewhere in the near vicinity that is turning it on. (Or your cat is watching it when you're not home.) Or you could just unplug it when you leave.
4/5/2009 6:14:30 PM • Haier HTN13R12S... • Answered on Apr 05, 2009
0answers
0answers
Datasheet
Be the first to answer 4/24/2007 3:32:49 PM • Haier HTN13R12S... • Posted on Apr 24, 2007Be the first to answer
Do I need an HDMI cable for my Wii system to work on my Haier tv
Yes you do
1/13/2022 8:03:58 PM • Haier Televison... • Answered on Jan 13, 2022
2answers
New remote for haier tv does not work. Removed batteries and pressed every button 30 secs. Put batterirs back in still dors notwork
Remove the batteries of remote control and press the on/off button for 1 minute facing the remote towards tv set. Then put the batteries back and yesss!! It works ??
12/14/2021 7:24:06 PM • Haier Televison... • Answered on Dec 14, 2021
My haier tv shows Run Channel Auto Scan, but remote is not working to set it. What can i do?
If you don't have a remote, Go to the menu where it says run channel auto scan, hover over the run button and .(on the tv) press volume up, volume down, input and menu at the same time. This (depending on your model) should start the scan
10/23/2021 4:38:14 PM • Haier Televison... • Answered on Oct 23, 2021
Haier 65UG6550G. There's power but no display. Someone gave it to me with no remote. Said one day it just stopped working.
Some sets won't power up without a remote control. Just try to buy its original or universal remote control. There is no other way. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. All the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check these sites too. http://remotesearch.blogspot.com/ https://elektrotricks.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops; as well as online shops. Visit the sites by Desktop computer and type in the brand name of your device in the search box at the right column. It will help you find the remote you have to buy. Mobille view has no search box.
7/13/2021 1:26:04 PM • Haier Televison... • Answered on Jul 13, 2021
Haier HTN13R12S 13" TV Logo
Popular Tags
16 questions posted
Top Haier Televison & Video Experts
Kolbrun...
Paul Bade
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Haier Televison & Video
Most Popular Question
remoe code haier tv model tdc1314s
  • Televison & Video
