20 Most Recent
JVC RV-NB1 Radio/Cassette/CD Boombox Questions & Answers
Power cord
I don't know what kind but I know where go to ebay or amazon
Where can I get one?
no. I just wanted to know if somebody could give me an idea where to buy one of these units now. There doesn't seem to be as many of them on eBay as there used to be.
Art
skype: wanderingsalsero
JVC boombox RV-NB 1 stopped working
Its the fuse (1.25A 250V slow blow) remove 12 allen screws on side panels, six each side (the very top and bottom allens are
for comestics) remove the woofer screws (just the two of the four)
that are facing the front panel.remove the 12 screws in the rear panel. 6 along the top, 4 along the bottom, 2 in the middle.
go to Radio Shack, Get a 2A 250V slow blow fuse (they dont have a 1.25A) Part# 270-1064 (4-pk about $3.00) reinstall & ROCK !!!!
I have a JVC RX-501 reciver and 2 speakers Sony(200W). I start the reciver and After 3-4 seconds it S make a sound like" bun bun " that S all... After 1-2 minute again..
The sound you're hearing could be due to a variety of reasons, such as a loose connection, a malfunctioning component, or a power issue. Here are some steps you can take to troubleshoot the issue:
Check the speaker connections: Ensure that the speaker wires are properly connected to the receiver and the speakers. Make sure that the positive and negative terminals are correctly aligned. You can also try disconnecting and reconnecting the wires to ensure a secure connection.
Check the power source: Ensure that the receiver is plugged into a working power outlet and that the power cord is securely connected to the receiver. You can also try plugging the receiver into a different power outlet to see if that resolves the issue.
Check the volume level: Ensure that the volume level on the receiver is not set too high. High volume levels can cause distortion and other issues.
Reset the receiver: Try resetting the receiver to its default settings. To do this, turn off the receiver and unplug it from the power source. Wait for a few minutes, then plug the receiver back in and turn it on.
If these suggestion don't help, you may have to seek professional repair.
2/2/2024 9:08:57 PM •
JVC Audio...
Answered
on Feb 02, 2024
1997 JVC RC-X270 does not read CDs
A bit of basic knowledge is required first;
Insert CD, the first thing the processor expects is to scheive Focus.
When Focus is acheived, the Spindle Motor will turn.
Either the Laser cannot Focus or there is an issues with the Spindle Motor.
Which is it ... if you know, then you will know which part or board has the issue.
1/29/2024 6:36:28 PM •
JVC Audio...
Answered
on Jan 29, 2024
