20 Most Recent Philips 25TR19C 25" TV Questions & Answers
ytyntytytyytytytyty
Philips 25TR19C... | Answered on Jan 07, 2011
Lets get started. First the TV you have does not have the new ATSC digital tuner built in. It uses the old NTSC tuner. You might find a few stations, however most major networks have gone Digital because the maximum power for NTSC is limited to 1000 watts. ATSC is the new digital standard for broadcasting both High Definition programs as well as standard definitions programs. So you will need a Digital converter box. They sell them at Radio Shack for around $60. You can get one on ebay for around $25. You will also need and antenna. A good old set of rabbit ears will work fine if you not to far (less than 25 miles) from the transmission towers. If your out in a rural area (greater than 25 miles from the tower) you may want to consider and outdoor antenna. Antennas Direct is a great source for antennas.
http://www.antennasdirect.com/
You can also get help estimating what kind of antenna you need at this web site:
http://www.antennaweb.org/aw/Address.aspx
However you may want to consider buying a new TV which will have a new ATSC tuner built in. You will still need and antenna.
Hope this helps.
Philips 25TR19C... | Answered on Apr 03, 2010
owners/users manual comes along with television.you can contact your dealar for that. if he does not provide you you can contact philips sercice centre located through out world regards
Philips 25TR19C... | Answered on Dec 30, 2008
is your tv on L2..what have you trouble shot so far?
Philips 25TR19C... | Answered on Dec 17, 2008
I have the same problem with a 20" RCA. If I turn on the TV from the unit itself, it goes off in 2 seconds. If I use the remote (universal) it always stays on. Just a solution that works for me. Best, Rickjsn
Philips 25TR19C... | Answered on Jan 23, 2007
Use code search on the URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
Philips... | Answered 3 days ago
This is a rather obscure manufacturer, and Philips has no assigned codes for it. However, there is an automatic mode for programming that universal remote. It is possible that some other manufacturer codes will work with your equipment. Try using the auto codes search function and you may get lucky.
Philips... | Answered on Nov 27, 2020
NON COMPATIBLE TO YOUR TV SET
Use code search on your Philips URC to find something that works. If a search through all codes stored in the URC fails, try a different URC.
Philips... | Answered on Nov 26, 2020
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Philips... | Answered on Oct 17, 2020
A little more info may be needed. Does your TV say this as soon as you plug in your firestick or does it say this when you are trying to play a video? If the first hold down rewind "<<" while holding top circle of remote (outer ring) for 15 seconds. It is likely that your TV resolution is out of spec for the Firestick (4k?) and you will need to enable "legacy" (older) resolution mode on the Firestick. If this does not work, there are you You Tube videos on enabling this mode for your Firestick. If the second, then you are trying to play a video with an unsupported video Codec, in which case you would need to find a supported video.
Philips... | Answered on Sep 13, 2020
Philips 25TR19C 25" TV Logo
9 questions posted
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
tv not working
  • Televison & Video
