20 Most Recent Philips 25PS40S 25" TV Questions & Answers
Not a big mystery. You just need a remote that can turn them off, unless the panel buttons have a CC menu option.
Philips 25PS40S... | Answered on Mar 02, 2018
JUST GO THE MENU AND PRESS INSTALLATION. SELECT AUTOPROGRAM. AUTOMATICALLY SYSTEM GOES TO DEFAULT MODE.
Philips 25PS40S... | Answered on Oct 04, 2011
walmart, universal remotes from $7.00 and up, the problem should be that channels up to 3 were blocked and you need to re program channel search on menu, cable or antenna option and then, locate channels with signal, if you watch tv from cable, the channels search only detected the channel 3 as a channel with signal, if the tv is not hdefinition, you wont need more channels, if it is hd, there is an option for dvd, antena (hd signal of course) and hdm or whatever signals capability, I hope I helped you, othewise, contact me and I will be more than happy to help, God bless
You can buy an universal remote at your local supermarket and you will be able to control and program the remaining channels. It will still be cheaper than getting a new TV.
Philips 25PS40S... | Answered on Mar 17, 2011
azt szeretném meg tudni hogy a philips német menűs tvét hogyan kel be állitani magyar csatornákra
Philips 25PS40S... | Answered on Jan 03, 2011
Hello
If your Philips TV is locked, just try this.
Philips sets use a four digit code to control the v-chip. The override code for Philips sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
Ok.
Philips 25PS40S... | Answered on Dec 11, 2010
Same thing here!!!!! It is soooooo annoying! Can't do it from the TV and the CC does not turn it off either.
Any suggestions would be so appreciated.
Philips 25PS40S... | Answered on Oct 23, 2009
Try a different cable, maybe a different television. If it's a wall box open it up and see if the cable inside fell off the connector. That happens sometimes. If you can, check the entire cable, and/or the other end of the line wherever it goes. If that doesn't work you'll probably need to call the cable company and have them fix it.
If the screen says "Front" on it, then you need to change the input. The "Front" input is for connections made to the front (video game, camcorder, etc).
See http://static.fixya.com/Manuals/P/Philips/25PS40S_25_T_A32FAF781D0920AD67B2FCB47EA09C06.pdf for the manual.
-=/ Daft Tech /=-
Hit The PIP Button On The Remote Until It Says CC OFF
Philips 25PS40S... | Answered on Feb 24, 2009
It could be the audio circuit faulty, either the IC or other parts - pls send to a service center.
Philips 25PS40S... | Answered on Nov 05, 2008
Probable causes 1) Magnetic field disturbance from near by equipments. eg. Audio Speakers. 2) It might also caused by shifting TV position 3) the degaussing might be faulty. Demagnetizing the set will resolve the problem.
Philips 25PS40S... | Answered on Sep 27, 2008
Picture tubes rarely go bad. You have a bad connection or something on the circuit board that is breaking down due to the temperature change . Probably an easy fix. Not something an unqualified person can do though. Your local shop should fix this for about $60-100.
Philips 25PS40S... | Answered on Aug 17, 2008
Philips 25PS40S 25" TV Logo
Popular Tags
31 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
tv only goes channel 3 dvd mode
  • Televison & Video
