20 Most Recent Philips Magnavox PPC936 36" TV Questions & Answers
Television
check the whole board for possible cold solder and resoldered it!
1/16/2007 7:23:32 AM • Philips Magnavox... • Answered on Jan 16, 2007
Philips LCD 42PFL3603D/F7 won't stay on until I've held the power button in a few times. The display comes on, then I hear a click and it shuts off. After a few cycles of this it stays on
Remove the cover on the back of the tv. Look for swollen or leaking capacitors. They kinda look like batteries. If they are bulging or leaking then that is your problem. You will have to de-solder the old ones off. Then solder the new capacitors onto the circuit board. Capacitors will cost about 20 dollars and installing them isn't that hard to do. It will fix your tv 99% of the time. So it is worth a try!
2/21/2024 9:36:48 AM • Philips... • Answered on Feb 21, 2024
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM • Philips... • Answered on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay https://www.ebay.ca > ... > Remote Controls Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ... $67.67 · ‎In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay https://www.ebay.ca > ... > Remote Controls PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost. US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com https://www.replacementremotes.com > philips > buy-... PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM • Philips... • Answered on Dec 05, 2023
ILive Sound Bar. I need the code for Philips Universal Remote to program my iLive Sound Bar please?
Best advice here https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote So many codes, good luck with that :>)
3-Digit Codes
  • 856
  • 734
  • 837
4-Digit Codes
  • 2113
  • 3175
  • 0816
5-Digit Codes
  • 33279
  • 72303
  • 32113
  • 23175
  • 33175
  • 42113
  • 31957
  • 43175
iLive remotes https://www.google.com/search?q=iLive+Sound+Bar+replacement+remote ..
11/19/2023 4:56:05 AM • Philips... • Answered on Nov 19, 2023
Needing to upgrade software on
yes i need software upgrade APPLICATION
11/18/2023 5:21:08 PM • Philips... • Answered on Nov 18, 2023
2answers
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM • Philips... • Answered on Oct 31, 2023
I need code for Philips t v using sony#rmt-d197a
The code you need to program your Philips TV using the Sony RMT-D197A is: 741
10/31/2023 3:27:55 PM • Philips... • Answered on Oct 31, 2023
I am looking to download Life View Philips software
Just to be clear, we are FIXYA, we aren't Philips, we just have a category for handy filing. The software isn't available online, just drivers. You would have to contact Philips direct. https://www.google.com/search?q=Philips+lifeview+software ..
9/24/2023 2:19:55 AM • Philips... • Answered on Sep 24, 2023
2answers
Philips 32PFL4664/F7 A parts
This sounds like a panel issue Sarah, if this is the case the set isn't repairable.
9/2/2023 9:52:08 AM • Philips... • Answered on Sep 02, 2023
Philips 3385v dvd/vcr recorder, brand new, Video plays only in fast forward
if new return it
6/30/2023 12:39:24 AM • Philips... • Answered on Jun 30, 2023
My Philips tv is just displaying setup and it's not exiting.. could anyone help out please
The EEPROM has lost it's boot log, replace the main board and the set should work
5/21/2023 12:00:58 AM • Philips... • Answered on May 21, 2023
Repair Philips 19PFL5402D/27
The ribbon cable is either loose or dirty.There could be a problem with the HDMI connections.
4/27/2023 6:19:49 AM • Philips... • Answered on Apr 27, 2023
Philips MCD716 not turning on :
You need the ribbon serial control cable to use the Phillips MCD716 to connect between the DVD player and the power amplifier. https://www.manualslib.com/manual/175139/Philips-Mcd716-12.html?page=11#manual . The power cord plugs into the power amplifier, https://www.manualslib.com/manual/175139/Philips-Mcd716-12.html?page=10#manual. The DVD player won't turn on without the control cable. Since the power amplifier only has a volume control, you can't do anything with the home theater system (change input, set the tuner frequency) without the ribbon cable. I hope this helps. Cindy Wells
4/26/2023 2:20:43 AM • Philips... • Answered on Apr 26, 2023
Philips Z11 TV/VCR Combo. I need the 4 digit universal remote code for TV VCR please.
I don't think you will get that to work, you have two units in one box https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote 'Z11' doesn't seem to be the correct alpha numerical model number. https://www.google.com/search?q=philips+z11+tv%2Fvcr+replacement+remote
Save Code list for future reference Refer to the setup ...
Philips https://www.p4c.philips.com > files > sru4000_17 PDF Save Code list for future reference Refer to the setup procedure below and look up the 3 digit code for your brand of TV, VCR, etc., from the list below. 2 pages Missing: z11 ‎' Must include: z11
Philips 4 digit remote codes for Combo devices - eliztech.com
eliztech.com https://www.eliztech.com > remotes > philips-4digit-co... Four digit code lists for HTIB and TV/VCR/DVD/DVR/SAT/CABLE Combos - Philips universal remote controls. Missing: z11 ‎' Must include: z11
Philips Universal Remote Control Programming Instructions
directutor.com https://www.directutor.com > content > philips-sru210... Program your audio and video devices with Philips Universal remote codes, simple steps for programming Philips universal remote...
3/15/2023 7:29:27 PM • Philips... • Answered on Mar 15, 2023
Philips 49PUS6501/12 (49", 4K, HDR, QLED). Replacing backlight in it.
Help in the videos
3/14/2023 4:44:46 PM • Philips... • Answered on Mar 14, 2023
2answers
Philips tv Model - 21PT3525/V7 I want EHT Number ?
The EHT number for a Philips TV model 21PT3525/V7 can vary depending on the specific version of the TV. However, the EHT number for this model is typically BSC25-0235 or BSC25-0217. It's important to note that replacing the EHT can be a dangerous process, as it involves working with high voltage components. If you're not experienced with electronics repair, it's recommended to seek assistance from a qualified technician who can perform the repair safely and properly.
3/4/2023 1:03:43 AM • Philips... • Answered on Mar 04, 2023
I have a Sanyo remote control and I need the 3 digit code for a Philips tv
default pass code (normally 0000, but also in some device 1234 or 8888 is used).
3/2/2023 12:47:06 AM • Philips... • Answered on Mar 02, 2023
Philips 4k 50put6400 no sound or picture wondering could this be the motherboard?
Sounds more like LED backlight than a main board issue
2/28/2023 9:54:00 PM • Philips... • Answered on Feb 28, 2023
How do I program my Magnavox universal remote to my Philips Magnavox fw530c mini Hi-Fi stereo
To program your Magnavox universal remote to your Philips Magnavox FW530C mini Hi-Fi stereo, follow these steps:
  1. Turn on your Philips Magnavox FW530C mini Hi-Fi stereo manually.
  2. Press and hold the "Code Search" button on your Magnavox remote until the indicator light turns on.
  3. Press the "Device" button on the remote, which should be the button corresponding to your stereo.
  4. Enter the 3-digit code for your stereo. You can find a list of codes for Philips Magnavox products in the user manual for your universal remote or online. If you do not have the manual or cannot find the code online, try entering codes 006, 007, 010, 011, 013, 016, 027, 033, 035, 043, 066, 087, 089, 114, 117, 118, 119, 120, or 123.
  5. Press the "Power" button on the remote to see if the stereo turns off. If it does, you have successfully programmed the remote. If it does not, repeat steps 2-4 with a different code until you find one that works.
  6. Once you have programmed the remote to control your stereo, test out the other buttons to make sure they work as well (such as volume control, track skip, etc.).
Note: If you cannot find a code that works for your stereo, you can also try the "Code Search" function on the remote. This may take some time, but it will automatically search for the correct code until it finds one that works.
2/26/2023 6:54:07 AM • Philips... • Answered on Feb 26, 2023
Philips Magnavox PPC936 36" TV Logo
3 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
television
  • Televison & Video
