20 Most Recent Philips 32RF82S TV Questions & Answers
The line output section circuit should be checked. If you wish to get more details, visit this site. Pull up older posts there. Details with circuit diagram are given.
Philips 32RF82S... | Answered on Mar 26, 2013
If conventional set and not LCD etc No high voltage is most likely--that area provides 20,000 plus volts to picture tube and also voltages for audio.
To repair or to replace set?
Philips 32RF82S... | Answered on May 03, 2012
The horizontal output section circuits to your TV should be checked.
Philips 32RF82S... | Answered on Apr 29, 2012
Good Day!
Please check your TV inside if the CRT tube is having heater or light in tube..
I think you don't have a heater or light on the CRT tube because you don't have a picture..
So you have to do is check the heater supply on the CRT socket it should have 6vac test it using multimeter (range in AC) after that trace the line from the CRT socket going to the secondary of the ply-back when you trace the line there is the resistor connected through please replaced it with the same type,ratings and value.
Thank you and good luck
Philips 32RF82S... | Answered on Jun 11, 2011
It needs repair.
If the line is vertical, then something is damaged on its horizontal circuit section on the mainboard.
If the line is horizontal, the vertical circuit section is damaged.
have it repaired to a qualified service center or person!
avoid switching it to avoid further damage on other parts!
Philips 32RF82S... | Answered on May 28, 2009
i have a phillips flatscreen plasma sound works but no picture.What can i do to fix it. is ther a chance that it could be something simple? or is this going to cost me a small fortune to fix.
Philips 32RF82S... | Answered on Oct 01, 2008
could be an intermittant connection on the picture tube curcuit board,or a bad picture tube, a bad flyback xformer,or a bad b+ capacitor off the flyback that controls the driver transistors on the crt board. Good Luck
Philips 32RF82S... | Answered on Mar 16, 2008
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Philips... | Answered on Oct 17, 2020
A little more info may be needed. Does your TV say this as soon as you plug in your firestick or does it say this when you are trying to play a video? If the first hold down rewind "<<" while holding top circle of remote (outer ring) for 15 seconds. It is likely that your TV resolution is out of spec for the Firestick (4k?) and you will need to enable "legacy" (older) resolution mode on the Firestick. If this does not work, there are you You Tube videos on enabling this mode for your Firestick. If the second, then you are trying to play a video with an unsupported video Codec, in which case you would need to find a supported video.
Philips... | Answered on Sep 13, 2020
Hi and welcome to the site,
Initially, postback with the model number.
BLOCKED as it implies indicates that the tray could not slide out; a common problem with some Philips models. Fix is to replace the DVD deck mechanism. Workaround is to always leave a disc inside.
Offhand, on most Philips models, there would be a manual eject slot at the bottom of the unit as shown in the representative image below.
Good luck and thank you for asking.
Philips... | Answered on Aug 26, 2020
What is the problem/s you faces with this device? Provide more details; please. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
View the site by desktop or web view on mobile devices to see the "search box". Type in the brand name of your set in search box; to get gathered the related posts.
Philips... | Answered on Aug 20, 2020
https://electronicshelponline.blogspot.com/
Philips... | Answered on Aug 13, 2020
They are only downloadable via your TV set.
Philips... | Answered on Jul 26, 2020
Philips 32RF82S TV Logo
Popular Tags
14 questions posted
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
tv black screen power
  • Televison & Video
