20 Most Recent Philips 27PS55S 27" TV Questions & Answers
If you're using a universal remote control with this TV, you have to setup it with setup codes to Sanyo TV, with this remote control. If you wish to get more details about setup codes and setup procedure, check these sites. http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Selecting the view option, either to Mosaic / Timeslide, can be selected by the dropdown list, at the top left of the display window, will make surf easy.
Philips 27PS55S... | Answered on Oct 09, 2013
If you don't know what PAL and NTSC signals are I would do some reading. It will explain what is happening. You can't use a ntsc device and set it to PAL. It doesn't work like that.
Philips 27PS55S... | Answered on Oct 30, 2012
did you check in the set up might set to off, if the settings is ok check the speaker if worn out. now if the speaker is still good at this time you will need to have trouble shooting in the amplifier circuit at the main board weather the amplifier is bad.
Philips 27PS55S... | Answered on Oct 02, 2012
if can not get with adjustment it could be a problem in the board, tried with re soldering cold soldered component joints at the video section.
Philips 27PS55S... | Answered on Sep 27, 2012
This is pretty common. Usually it's because of bad solder connections at a part called the vertical output integrated circuit. Resoldering the bad connections is often all it takes to fix the trouble. While it's a simple repair, unless you have experience doing electronic soldering you should have this done by a professional. It's possible to more damage. Take the set to a shop for an estimate (won't cost as much as a new TV).
Philips 27PS55S... | Answered on Sep 26, 2012
its obviously a feedback problem did u open the back of the tv and check the wires or the speakers?
Philips 27PS55S... | Answered on Mar 03, 2012
U still have the tv original remote wright?Yes?Used the tv remote press the Menu button.Pick and go into the tv Sound Setting adjustment have all sound functions setting in there.
Philips 27PS55S... | Answered on Aug 23, 2011
Sorry it the picture tube it's going out. I'm surprise your color didn't fade first.
Philips 27PS55S... | Answered on Mar 14, 2011
there is a problem in your tv amplifier section.
Philips 27PS55S... | Answered on Feb 21, 2011
Well I don't need help any more with this item and by the way THE PANEL FOR THIS LCD TV GOES FOR $200 to $250 I found them all over the internet the part # is LC320 WXN SA-B! SO in short IT IS cheaper to fix than replace!!!!!!
Philips 27PS55S... | Answered on May 23, 2010
No.All CRT tv don't have the digital tuner inside.So not a digital tv.
Philips 27PS55S... | Answered on Jan 23, 2010
On the original TV remote press the button to the left of the 0 is a button marked "CC" just press this button to cycle through the 4 different closed caption options.
Good luck...
Philips 27PS55S... | Answered on Jan 13, 2010
I have one also, I'm looking for a manual out of boredom i guess, but, everywhere i look, i see all of my tv's probs. As far as the coax input, unless you have a solder kit, not much you can do other than get an adapter, use the a/v, or a vcr. the tv going off after a few mins, I solve by hitting the guide button on my dish receiver or what ever you have to stimulate the tube.... I know that doesn't sound right, but you know what I mean. It sort of warms it up. That also works for the sound. It really does work for me, its just basically, getting it to "wake up"
Philips 27PS55S... | Answered on Nov 17, 2009
Philips 27PS55S 27" TV Logo
Popular Tags
32 questions posted
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
am looking buy philips 32hfl5860d 27 lcd
  • Televison & Video
