20 Most Recent E-Machines etower 600is PC Desktop Questions & Answers
How can I get proper drivers and Windows Millenium software downloads by machine serial number?
Windows Millenium has not been supported by Microsoft for many years now, and there are no legacy drivers or other downloads available for it. Best thing you can do is to load Windows 7 or later on the machine (most machines that were capable of running Windows Millenium are also capable of running Windows 7).
5/20/2015 10:15:51 PM • E-Machines... • Answered on May 20, 2015
My etower 600 refuses to find hdd, why,help
Check the settings of the boot device on the BIOS make sure that the HDD is the first one to boot
8/7/2014 8:54:30 AM • E-Machines... • Answered on Aug 07, 2014
How do i access my boot menu on an etower 600is
Generally its ESC, F1, F2, F8 or F12, if you can get to at least the BIOS menu you can probably change the boot sequence to your liking.
1/5/2013 10:52:00 AM • E-Machines... • Answered on Jan 05, 2013
Pc wont power on
I suggest that if really want to keep tour PC and have some $$$ (200) then buy a poer supply and a mobo and replace it.
11/23/2011 11:34:26 AM • E-Machines... • Answered on Nov 23, 2011
I can't get a PCI video card to work. It
remove the card from the slot .clean the contacts with eraser and fix it back
8/5/2011 1:16:54 PM • E-Machines... • Answered on Aug 05, 2011
I have an old emachine
If you have an extra pci slot then you can buy yourself a network adapter card. There are plenty available on your local shop or on ebay. You can choose from wireless, wired or one that comes with both.
Hope this helps.
5/4/2011 8:06:14 AM • E-Machines... • Answered on May 04, 2011
I use emachine (
Yes a USB 2.0 PCI adapter card but Ethernet at a 100 megs is better than USB at 21megs.
2/10/2011 6:27:50 AM • E-Machines... • Answered on Feb 10, 2011
I need emachine etower 600is intel processor
The eMachines eTower 600is uses an Intel Celeron III processor that operates at a maximum frequency rate of 600MegaHertz. (600MHz)
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=eTower%20Series&model=eTower_600is
The Intel Celeron 600 uses a Socket 370 processor socket.
http://en.wikipedia.org/wiki/List_of_Intel_Celeron_microprocessors#.22Coppermine-128.22_.28180_nm.29
There is a locking arm on the side of the Socket 370 processor socket, that is unlocked by easing the arm over to one side to clear a lock tab, then the arm is lifted up to remove the processor.
Example of a Socket 370 processor socket,
http://en.wikipedia.org/wiki/Socket_370
The eMachines eTower 600is uses an Intel 810 chipset, for the motherboard chipset.
[Chip and Chipset are slang terms used for Integrated Circuit, or IC]
The Intel 810 chipset, supports processors with a 66MegaHertz Front Side Bus. (66MHz FSB), or 100MHz FSB.
In an additional link, I will give a recommendation of where to buy an Intel Celeron 600, that uses a 66MHz FSB.
I'm not advertising for this place, it's just a place I have used, and have had good results.
Also information on the Intel 810 chipset.
You could also use an Intel Celeron 700MHz processor, but better still you could use an Intel Pentium III 933MHz processor.
Pentium's typically have Two times, the L2 cache that a comparable Celeron has.The more L2 cache a processor has, the faster it's going to process information.
I also know it will work because out in my shop I have an eMachines T1090, that has an Intel 810 chipset, uses a Socket 370 processor socket, and has an Intel Pentium III 933MHz processor in it.
(Made in 2001, and still works good to this day)
The Intel Pentium III 933MHz processor uses a 100MHz FSB.
The Intel 810 chipset supports processors that have either a 66MHz FSB, or a 100MHz FSB.
If you are not familiar with computer hardware technology, then I have just thrown a whole lot of information at you that is unfamiliar.
Should you like me to break down the information, I would be glad to. Just state so in a Comment.
3/25/2010 3:02:53 PM • E-Machines... • Answered on Mar 25, 2010
2answers
How do i use my recovery disk to recover my pc
put the recovery disk in your dvd drive and restart your pc.
when you see the message "press any key to start from dvd" press enter.
the restore procedure will begin.
1/25/2010 9:53:14 PM • E-Machines... • Answered on Jan 25, 2010
When i turn on my computer it beeps 3 times but
Keyboard error.
12/23/2009 1:10:44 AM • E-Machines... • Answered on Dec 23, 2009
I just need the network driver for a friends
Hi friend,
you need to open www.download.com then you need to type your model then you will find out the link for download....you need to install this software .......
12/22/2009 12:01:10 AM • E-Machines... • Answered on Dec 22, 2009
Try to turn on computer and the fan blows, but
Sounds like the power supply or the motherboard. If you have another computer available, you can test the power supply. Just "borrow" the power supply from the other computer. If it still won't come on, then the motherboard might be bad and you'll need replacement.
If you swap the power supply and the motherboard is bad, you will not hurt the working power supply. The motherboard is already dead and won't feed back to the working power supply.
Also, if you have flashed your BIOS recently and it has not completed successfully, you might have a dead motherboard and you will need to replace it. You would know if you flashed or updated your BIOS chip.
Hope this helps!
10/26/2009 12:36:38 AM • E-Machines... • Answered on Oct 26, 2009
2answers
My computer is stuck with a content ratings
boot serivece pack -3. there u can get passport change option
10/9/2009 11:30:38 AM • E-Machines... • Answered on Oct 09, 2009
What would be a compatible cpu upgrade for the 600is
replace the RAM of higher memory capacity n by uninstalling the unwanted software can increase the processing speed.....
4/30/2009 6:32:07 PM • E-Machines... • Answered on Apr 30, 2009
Device manager error !
It sound like you need a device driver which win2000 may not included. Try this link:
http://www.driverfiles.net/Other/Emachines/eTower-600is/download/page,sh,41224,568,3,.html
12/5/2007 12:38:08 AM • E-Machines... • Answered on Dec 05, 2007
Why does it say hard drive not found when it has one?
Check your cable connections.
11/17/2014 3:41:12 AM • E-Machines... • Answered on Nov 17, 2014
Super drive
You can go to BIOS setup and check that CD drive is recognize there or not, If not then there must be some problem with CD Drive or connectivity of CD drive with computer, If it is showing there then you can follow this tutorial and change with the registry.http://support.microsoft.com/kb/314060
10/17/2013 7:13:29 PM • E-Machines... • Answered on Oct 17, 2013
Bios setup
To reset bios, turn computer off and remove side cover, remove coin battery from motherboard and jump appropriate pins on the motherboard to clear cmos. These pins can be found in the owners manual online at the E-machines website.
9/22/2013 6:53:10 AM • E-Machines... • Answered on Sep 22, 2013
E-Machines etower 600is PC Desktop Logo
20 questions posted
Top E-Machines Computers & Internet Experts
Ekse
Michael Thomas
Michael Thomas
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
etower E-Machines
  • etower E-Machines
Most Popular Question
old emachine
  • Computers & Internet
