20 Most Recent
E-Machines eMonster 550 PC Desktop Questions & Answers
No pic on monitor
Please double check, you should have two cables out of the monitor and connected.
1. The power cable to your UPS/ AC switch.
2. display cable connected to the CPU(main box).
Based on the information you gave one or both of these cables are not connected/switched on.
Thanks.
E-Machines...
Answered
on Feb 03, 2010
Hi i have emachine 8230 tower
firstly lets think why a Working pc would no longer BOOT. The boot process then. a pc starts the bios which POST's. this results in ONE BEEP which might be followed by messages(if you get several beeps then they are like morse code long/short and count out an error code). when you get your ONE BEEP the pc is working. when it then HANGS(appears to do nothing) its usually because of either a) the cd drive is duff so disconnect its cables. b) the hard drive is duff so disconnect its cables c) the hard drive hasnt quite died yet but has some very slow sectors and is making the Clackety Clack of the heads recalibrating every few seconds. d) there could be a a gpu card bios glitch and your pc is running but you just have a blank screen. some hints then 1) never start removing parts as that corrupts the CMOS(the battery backed up configuration for your BIOS) so you may need to clear your cmos. 2) never play with the idea of changing ram sticks as people usually end up putting them in any old slot(which may result in a non working pc). make sure a PAIR is fitted in slots 0/2 and a separate matching pair in 1/3 slots not in slots 0/1 which is two half pairs. Other factors. 1) a short circuit. your PSU has built in protection, if the psu fan(inside case of the psu) turns and kicks back and immediately stops you have a short circuit and its cuts the power to avoid a fire/meltdown, which could be caused by high wattage gpu(>60 watts) without its extra power cables fitted or wrongly connected front usb cables or removing a mainboard and fitting it into a new box where the board has its support posts NOT lined up with the holes fro the screws so the post is touching underside of the board circuits. hope some of that helps.
E-Machines...
Answered
on Nov 22, 2018
E machines model et1831 will not boot up
try booting to safe mode. by using f8
if that works, try a system restore to a previous date.
if that does not help, then it must be a windows corruption and parallel install or repair install will be needed, it can also be fixed by manual troubleshooting and repairing the files.
E-Machines...
Answered
on Jul 30, 2015
