20 Most Recent
Philips VR630 VHS VCR Questions & Answers
Where can i get help
I'm sorry to say this but many video heads are more expensive than buying a new machine. But you might get lucky. I did see some parts for sharp at Curry's Partmaster. And you can also try Grandata.
Also try CPC, Willow Vale Electronics.
I have just bought a
The chances are that the person who supplied it to you gave you a Phillips remote for another VCR. Many makers remotes will work parts of a different model of the same firm, but only the true remote will operate ALL functions.
If you have the user manual check to see if it list the part number of the remote. If you don't have it look around the net for Philips VR630 remote. See if it matches yours. If it doesn't you will have to replace it.
Philips vr630 vhs
I get the same problem with one tape (it's about 20 minutes long) .. it also shows a '4' ... when you press the power button it ejects the tape... some tapes are fine ...
VHS tape stuck in machine. How do you remove it ?
Sometimes you can unplug the VCR for a min. or two. Then plug it back in. This will reset the processor. If the tape does not come out, pull the top off and see if the tape is out around the Head. If it is, you have to manually move the gearing to back ever;ything up. The tape its self will not retract back into the cartage, If you can get the cartage backed out, take a pencil and on the bottom of the cartage there is a hole. Push the pencil in the hole(,this releases the spindles) and turn one of the spindles and this will pull the tape back into the cartage. The tape probably won't be any good. Tapes get stuck for many reasons. Sometimes the heads are so dirty the tape sticks to the head and maybe the tape its self is wore out. Hope this is helpful.
Cassette stuck in video
I am a sanyo VCR technician and i will share to you what i had encountered. the problem of your VCR is in the mechanism "slide front" unable to push out the ejector portion of the tape. If you can locate this part just push it so that the tape will eject.
VCR eats the tape
you have a bad take-up reel clutch or a belt on the bottom of the player mechanism that is causing this trouble.
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
