20 Most Recent Olympus MJU 300 Digital Camera Questions & Answers
Hi, I have got an
There are several reasons why could happen: 1. 2GB is a lot of space compared to 16MB. The camera checks the card each time you switch it on. 2. Card is corrupt & should be reformatted. 3. Card is defective & should be replaced.
10/5/2017 11:47:21 PM • Olympus MJU 300... • Answered on Oct 05, 2017
manual
Last software download
are you trying to download your photos onto your computer if so you can take the sd card out and put it in your computer slot for sd and download them from there. or you can go onto computer and download the software for that camera.
1/24/2013 3:22:49 PM • Olympus MJU 300... • Answered on Jan 24, 2013
Mju 300 lens barrel will not retract
check the batteries! all features will not work on drained batteries. If the problem is in the hardware, then think about getting a new camera.
4/10/2012 2:51:21 PM • Olympus MJU 300... • Answered on Apr 10, 2012
I have just bought a
Having gone over four months without a response to my query, I assume my suggestion to use a card reader solved the problem.
11/1/2011 12:56:16 AM • Olympus MJU 300... • Answered on Nov 01, 2011
Can i use 2 gb
Hi I have just bought a u 300 it came with all the software all instructions spare batteries and such but i cant find anything in any of the instructions about how to get the remote to work. have tried a new battery ! can anyone help please
9/23/2011 3:38:29 PM • Olympus MJU 300... • Answered on Sep 23, 2011
Hi, bought MJU300 second hand with no disc and
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support How to easilydownload Pictures from Digital Camera
heatman101-=
8/26/2011 3:05:36 AM • Olympus MJU 300... • Answered on Aug 26, 2011
Is the olympus mju 300 digital camera compatible
Hello
Yes, this camera is compatible with windows 7.
Let me know if you need any further assistance.
Kind regards
Andrea
9/12/2010 9:40:41 PM • Olympus MJU 300... • Answered on Sep 12, 2010
The lens will not come out when i slide the cover,
Dear feldt,
There is a mechanical displacement in your camera. So get it serviced....
Actually Digi Cams are very delicate. So even small amount of **** or shock also can caused such type of problems... Or there could be a problem between your Battery mechanism... You can also try be inserting another battery.
5/1/2010 1:35:33 PM • Olympus MJU 300... • Answered on May 01, 2010
Lens continues to go out and then in
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
3/3/2010 12:52:00 AM • Olympus MJU 300... • Answered on Mar 03, 2010
Olympus mju 300 - not recognised by Windows 7
Do what the pros do...use a card reader.
2/8/2010 9:54:14 PM • Olympus MJU 300... • Answered on Feb 08, 2010
Camera won´t start:
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
10/13/2009 6:44:45 PM • Olympus MJU 300... • Answered on Oct 13, 2009
When opening lens barrier camera will not switch
The problem you are describing is a problem with the sensor that is behind the sliding lens cover door. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
5/5/2009 2:40:10 PM • Olympus MJU 300... • Answered on May 05, 2009
Olympus stylus 300 zoom won't turn on / move
Olympus will charge a flat rate repair fee for this product. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
3/16/2009 2:52:08 PM • Olympus MJU 300... • Answered on Mar 16, 2009
Daughter plugged a phone charger in camera, now it doesn't work
hello there! thanks for using Fixya.com!!
I suggest that you try another battery or better yet a new one just to troubleshoot. Maybe a damaged occured with the battery. Hope that your camera would be fine. A short circuit happened of course if we use a different kind of charger that are not applicable or not compatible with. Pls check your warranty card as what you told that it is brand new and for sure it is still under warranty. We just hope that they will cover that kind of incident. I know it can be fixed but we don't want to waste any penny. so make sure that your warranty card is still with you.
hope this will help you! cheers!! don't forget to mark! thanks!
2/17/2009 8:59:56 AM • Olympus MJU 300... • Answered on Feb 17, 2009
MJU 300 battery charged .slide open no power
This may be a repair issue with the sensor that is located behind the front sliding lens cover. You may want to call Olympus Customer Service to discuss repair policies and procedures. Their telephone number is 800-622-6372 option 2 and then option 3
2/11/2009 7:02:04 PM • Olympus MJU 300... • Answered on Feb 11, 2009
13answers
Black Screen
I just started having this problem with my canon PowerShot A310 and checked their service website which says "Effective immediately, and regardless of warranty status, Canon will repair, free of charge, products exhibiting the above-mentioned malfunction if the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair." Here's the website link: http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=221&modelid=9829
1/15/2009 3:40:45 PM • Olympus MJU 300... • Answered on Jan 15, 2009
Suddenly the camera is not working !!!
You have to try format the memory card in your camera ?
You write, that "setup" is working
Might be the need of memory updating - computer does mainly harms to the camera if used to operate inside of camera ;-(
Own experience and twice - is, that the camera had lost all pictures from memorycard.
Happily enough a program downloaded from the net was helping.
Wish good luck!
murtomaa
11/17/2008 9:04:47 AM • Olympus MJU 300... • Answered on Nov 17, 2008
Olympus MJU 300 Digital Camera Logo
41 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Mju Olympus
  • Mju Olympus
Most Popular Question
mju 300 lens barrel will not retract
  • Cameras
