20 Most Recent Olympus Camedia C-310 Zoom Digital Camera Questions & Answers
this is an old camera which uses xd picture card format. latest format in use is sd. hence, production of chips and cameras with xd stopped years ago, and a new xd may be avaialble online, but at a very stee price. Approx $25 per peice (similar sd costs $4 per piece)
Olympus Camedia... • Answered on Nov 06, 2013
The camera has a 5x optical zoom lens. To enable the additional 2x (2 times 5 equals 10) digital zoom, enable the digital zoom in the shooting menu as shown on page 19 of the manualhttp://www.olympusamerica.com/files/D540_ZoomBasicManual.pdf
Olympus Camedia... • Answered on Apr 28, 2013
Select MODE MENU, CARD, CARD SETUP, then press cursor-right.Full details are in the "CARD SETUP - Formatting cards" section starting on page 91 of the manual.
Olympus Camedia... • Answered on Aug 14, 2012
Try using tools like a flathead screwdriver.It'll take some grunting, and a little patience, but it should come out.
Hope this helped!
Be Sure To Rate macapplezoo 100% Or Whatever You Think I Deserve!
Olympus Camedia... • Answered on Jun 03, 2011
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Olympus Camedia... • Answered on May 19, 2011
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Olympus Camedia... • Answered on Apr 21, 2011
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as the free Picasa program ( http://picasa.google.com ).
Olympus Camedia... • Answered on Apr 07, 2011
Format the card in the camera if you can. If not format it FAT in windows with a card reader and then reformat in the camera.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Olympus Camedia... • Answered on Feb 28, 2011
Your camera uses xD cards, not SD. Now if you are using a micro-SD adapter, make certain that the cards you are using are 2GB or less standard micro-SD cards. Your camera will not work with 4GB or larger micro-SDHC cards as that format had not yet been invented when your camera came out.
Olympus Camedia... • Answered on Dec 23, 2010
I have the same issue with my Olympus Stylus 720 SW. Extremely annoying and Olympus customer support has been silent
Olympus Camedia... • Answered on Dec 20, 2010
Please elaborate your problem providing us with more details of the problem.
Thanks for using FixYa.
Olympus Camedia... • Answered on Dec 06, 2010
Try this: create a folder on your desktop and label it videos. Then, using the card reader, open the files on your screen and drag and drop the videos into the folder. You need a player on your computer to play the videos so you may have to experiment trying to open them with various programs. You could also download a free copy of Quicktime from apple.com It will play many different forms of videos.
Olympus Camedia... • Answered on Nov 26, 2010
When you removed the card from the computer, did you: A. forget to use the "safely remove hardware" function B. delete the pics using the computer instead of the camera Either of these could cause your problem. If the pics are safely on your computer, I suggest you format the card in the camera.
Olympus Camedia... • Answered on Oct 14, 2010
Simple press it a little and it will then eject a bit so you can grasp it for removal.
Bob
Olympus Camedia... • Answered on Oct 12, 2010
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Olympus Camedia... • Answered on Sep 30, 2010
for an old camera battery i would start looking on e-bay,,you may get lucky
Olympus Camedia... • Answered on Aug 05, 2010
Yes 2 different AA NiMH batteries.
Olympus Camedia... • Answered on Feb 25, 2010
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it. The position nearest the contacts unlocks it. If the switch is already in the proper position, try sliding it fully the other way and then back again.
If that doesn't work, try another card.
Olympus Camedia... • Answered on Feb 05, 2010
Olympus Camedia C-310 Zoom Digital Camera Logo
42 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Camedia Olympus
  • Camedia Olympus
Most Popular Question
difficulties finding 32mb picture card
  • Cameras
