20 Most Recent Olympus Camedia Brio D-150 Zoom Digital Camera Questions & Answers
Features
The D200L had a focus free 5mm wide angle lens, which focused from 19 inches to infinity for sharp accurate photographs. For close up work, the D-200L focused down to 7.9 inches. The camera had built in 1.8" color LCD, optical viewfinder, automatic four mode flash and 2 MB of built-in memory. It had a 330,000 pixel CCD. The resolution was 640 x 480, ideally suited for web designers or just to e-mail a picture. It came packaged with Adobe Photo Deluxe, Twain and Plug-in software for acquiring and editing the digital photographs.
8/31/2005 10:11:15 AM • Olympus Camedia... • Answered on Aug 31, 2005
Quality mode setting
Press the monitor button. The amount of images that can be stored and the selected quality mode will appear in lower-left corner of the LCD display.
8/31/2005 10:10:11 AM • Olympus Camedia... • Answered on Aug 31, 2005
Reference Manual
The CD-ROM provides a full Reference Manual in PDF format on the CD-ROM. Adobe Acrobat which is provided on the CD-ROM is necessary to view the PDF manual. The printed manual that is included with the camera is a "Basic Manual".
8/31/2005 10:09:14 AM • Olympus Camedia... • Answered on Aug 31, 2005
Contents of the Brio
Brio D-150 Zoom or C-1 Zoom camera, 8MB SmartMedia Card, (1) CR-V3 Lithium Battery Pack, Camedia Master Software, Win/MAC USB Cable, NTSC A/V Cable, Instruction Manual, and Carrying Strap.
8/31/2005 10:08:15 AM • Olympus Camedia... • Answered on Aug 31, 2005
SmartMedia Card
D-150/C-1 Memory Card Storage Capacity Quality Resolution # of Storable images SHQ 1280 x 960 8 or more HQ 1280 x 960 24 or more SQ 640 x 480 82 or more
8/31/2005 10:07:02 AM • Olympus Camedia... • Answered on Aug 31, 2005
2answers
Olympus Camedia E10 won't power on with AA NI-MH batteries but works fine with AA ALKALINE, what can I do?
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period. Always charge sets of batteries (2 or 4) together. Make sure your rechargeable batteries are all good. One defect in a set is killing for the whole set Don't use barrettes from different sets or brands together. I had one brand good NiMH batteries and a very expensive charger from the same brand. The charger destroyed all my rechargeable (more than 60 now). When I first discovered the batteries were dropping out, I stopped using the charger, but it did not prevent all batteries to die in the following months. Every time on dropped out I had to change the set. I tried using up the others by grouping the ones with the same Ri, but not longer then a few months and I had a box full to trow away. Never use a quick charger, capable of charging them within an hour or faster. Us a charger that indicates the Ri is still low enough, so you can see what batteries are bad. Check you are using a charger for NiMH batteries. I would try another set (new) because buying Alkaline is also not cheap. I used 2700 mAh and later 2600 mAh rechargeable, all dead now. since a few weeks I'm now using 2300 mHh from another brand, costing 1/5 of the "best" I had before, and they are doing great. I won't charge them with the quick charger. Never use manganese (Zinc-Carbon) batteries in electronic devices. These batteries are only to be used in flash lights.
12/7/2016 8:12:01 AM • Olympus Camedia... • Answered on Dec 07, 2016
How to use zoom on c-860L
This 14 year old camera, does not have a zoom lens. It has a 5,5 mm lens, giving it a angle of view of about a 35 mm lens of a Full frame camera. However, you should be able to zoom digital 2 times. I can't find a manual, to help you on this, but the quality will be the same as cropping into a frame on your computer. So if you do put the pictures on a computer, you also can "zoom" in to the parts you want. Be aware a 1 megapixel camera, does not offer that much of detail.
10/27/2014 11:34:04 AM • Olympus Camedia... • Answered on Oct 27, 2014
Zoom error olympus
Lens is out of possition and stuck.
7/31/2014 7:19:31 PM • Olympus Camedia... • Answered on Jul 31, 2014
Camedia e20 problems
Put memory card into camera right way around.
7/5/2014 6:38:40 PM • Olympus Camedia... • Answered on Jul 05, 2014
Camedia e20 wont record picture
Hi, any error messages?
6/20/2014 1:31:49 AM • Olympus Camedia... • Answered on Jun 20, 2014
0answers
Manual setting of focus
Like many point&shoot cameras, the SZ-12 does not have manual focus. The closest you can come is to point the camera at the object your want in focus, press the shutter release button halfway, then frame the photo the way you want it and press the shutter release button the rest of the way.
12/16/2013 4:24:41 PM • Olympus Camedia... • Answered on Dec 16, 2013
Busy signal when I try to download photos
What model Olympus camera? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (http://picasa.google.com).
11/23/2013 9:52:37 AM • Olympus Camedia... • Answered on Nov 23, 2013
Busy comes up when I try to download photos
What model Olympus camera? Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (http://picasa.google.com).
11/22/2013 11:24:51 PM • Olympus Camedia... • Answered on Nov 22, 2013
Find PHOTO on hard drive
To be sure your camera can connect to the PC. if it does, download a photo recovery software called hodo photo recovery which help me before. you can recover your photos by it.
8/7/2013 9:12:04 AM • Olympus Camedia... • Answered on Aug 07, 2013
Olympus Camedia Brio D-150 Zoom Digital Camera Logo
6 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
David Shaub
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Camedia Olympus
  • Camedia Olympus
Most Popular Question
features
  • Cameras
