20 Most Recent Meade ETX-90EC (325 x 90mm) Telescope Questions & Answers
I can not get the telescope to focus. The viewfinder will not focus in. and can't see anything out of the out of the optical tube.
This type of telescope is viewed from the small tube at the rear. Use the longest lens you have. Most people think that they need magnification, but that is not accurate. A 5 mm lens will only have 1/6th the field of view (how much sky you see) compared to a 30 mm. The picture below was taken through a 50 mm lens.
12/23/2014 5:37:18 PM • Meade ETX-90EC... • Answered on Dec 23, 2014
I have a Meade ETX-90/ec
The bolt is stripped away from the plastic knob-- TAKE THE vertical lock knob off and inspect the bolt head-- you can use a STRONG glue to fix it -- epoxy or something similar.
9/17/2011 8:41:02 PM • Meade ETX-90EC... • Answered on Sep 17, 2011
Focus knob just backs out of unit
There is a tiny setscrew on the side of the knob. Tighten this screw and the knob will stay on the rod coming out of the scope.
www.telescopeman.org
www.telescopeman.us
9/17/2011 1:41:06 PM • Meade ETX-90EC... • Answered on Sep 17, 2011
Meade ETX-90EC . i cant
The flip mirror has fallen off inside the scope. This must be returned to Meade for repair. Here is their customer service phone number:
http://www.meade.com/support/index.html
9/17/2011 3:58:52 AM • Meade ETX-90EC... • Answered on Sep 17, 2011
Cannot focus the ETX-90. Feel
There is a small (tiny) set screw on the side of the knob. Make sure the screw is tight.
7/27/2011 12:07:53 AM • Meade ETX-90EC... • Answered on Jul 27, 2011
I purchased a Meade ETX 90 EC 325X90 MM Telescope
It is very simple.Their is one shaft appear near eyepice.please you go at electronics componant shop and buy a knob which is suitble to fix.You focus button ready to work.
7/9/2011 7:24:55 AM • Meade ETX-90EC... • Answered on Jul 09, 2011
I had to clean the
Go to the Mighty ETX web site:
http://www.weasner.com/etx/menu.html
There are many pictures and technical documents there that will show you how to dis-assemble and reassemble these telescopes.
5/9/2011 8:21:28 PM • Meade ETX-90EC... • Answered on May 09, 2011
I bought a used etx90 with autostar. The scope
The contrast and brightness can be reset --- here is the manual -- how to do this is listed in the manual. If this does not repair the controller then you will need to buy a new hand controller-- the 497 hand controller is available used on Ebay from time to time.
http://www.meade.com/manuals/TelescopeManuals/ETXtelescopes/ETX-90%20w-autostar%20man.pdf
Manual down load above--
5/9/2011 8:18:47 PM • Meade ETX-90EC... • Answered on May 09, 2011
I have an Meade ETX
Meade usually will not sell you parts. However you can call them and ask.
Usually they want you to return the scope for repairs. They can fix this but you may not like the charge which is usually about $150- $175.
4/15/2011 9:50:22 PM • Meade ETX-90EC... • Answered on Apr 15, 2011
Meade ETX-90EC the declination lock won't
Unfortunately, you will probably have to send the unit in for sevicing, to restore this function. This type of scope is a highly precision device, and parts can wear, causing a loss of certain functions. I wouldn't recommend trying to take the unit apart, unless you're a super mechanical person. Even if you did, you'd have to identify the worn or failing part, and that would be a challenge without the tools and replacement parts they have at their repair facilities. Some cities have "sky clubs" and some of the people are avid skywatchers, and might know something about this particular problem, and may be of help, but that might your best alterntive to having it serviced right away. Often times, a switch or part can get slightly compromised by dust, or lint, and require a minor cleaning.
Here's Meade's Support Site, in case you don't have it:
http://www.meade.com/support/auto.html
Good luck, and hope this helps.
3/28/2011 7:50:37 PM • Meade ETX-90EC... • Answered on Mar 28, 2011
Focus knob wont work juat spins setscrew is
The gears could be stipped inside the scope. Make sure the shaft isn't broken also, when you take it apart to inspect it. If you find a damaged gear or broken part, contact Meade to see if that part is available. If you have trouble inspecting the unit to find the problem, you could take it into a camera repair shop, and see if they can assist you in determining the problem. Here's Meade's support site:
3/20/2011 9:37:42 PM • Meade ETX-90EC... • Answered on Mar 20, 2011
My whole lense has snapped of the base of my meade
Meade can repair these scopes but they will want you to return the scope--
Contact them here:
1/21/2011 4:30:23 AM • Meade ETX-90EC... • Answered on Jan 21, 2011
Usb-serial adapter doesnt work port
Try another one-- some work and some do not. The one sold by scopestuff.com works.
www.scopestuff.com
1/13/2011 1:53:10 AM • Meade ETX-90EC... • Answered on Jan 13, 2011
The OTA support on my ETX 90 broke. I actually
There is a "BOLT" do it yourself fix for this on the Mighty ETX web site. Seach for DEC Fix --- or send Mike an email.
here is a direct link:
http://www.weasner.com/etx/techtips/etx_90_dec.html
12/30/2010 4:56:26 PM • Meade ETX-90EC... • Answered on Dec 30, 2010
Meade ETX-90EC (325 x 90mm) Telescope Logo
Popular Tags
42 questions posted
Top Meade Optics Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Meade Optic Expert? Answer questions, earn points and help others
View Most Popular
Meade Optics
  • Meade Optics
Most Popular Question
meade etx 90 ec
  • Optics
