20 Most Recent Olympus D-600L Digital Camera Questions & Answers
manual
I have a D-620L camera
It may be a problem with being full or locked ..Ny advice is to download (copy paste ) all the pictures and videos from them ...and after that insert them back ..and see if hey work ...Also formatting them again in the camera will be a smart action ..Just get into the main menu ..under storage ...choose memory card ..and in the options format card ..This action will delete any files on it ..so a complete back-up (store them in a computer or disk ) will be needed if you have files on them ..
If even if you format them ..they are still not functional ...it means that they have either something damaged or they were set in a write protected mode...Check them in the computer 's card reader..right click on them and under properties..see if the cases for read only is ticked..If so ..remove the sign in the read only case..or ...just format them once in the computer ..insert them in the camera and format them again ..
If they can be seen for reading files ..they has to work for storage also ..
1/10/2011 4:11:06 AM • Olympus D-600L... • Answered on Jan 10, 2011
Just got it need help
You can get the manual here:
http://www.olympusamerica.com/files/oima_cckb/D500600Lmanual.pdf
12/11/2010 12:02:12 AM • Olympus D-600L... • Answered on Dec 11, 2010
I have 2 Olympus D-600-L cameras. One is able to
i have a olympus D600-L camera that has no picture on view finder or lcd screen.when camera powers up there is no error code.seems like a blank screen.
9/17/2010 8:54:09 PM • Olympus D-600L... • Answered on Sep 17, 2010
My olypus D600L says no picture on screen
http://olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=97
Here is the link where you can download the manual from the Olympus website
3/12/2009 3:41:16 PM • Olympus D-600L... • Answered on Mar 12, 2009
2answers
SmartMedia cards
The D-500L and D-600L can use a 2, 4, or 8 MB SmartMedia card. The D-620L can additionally use a 16 or 32 MB SmartMedia card.
6/5/2007 5:18:16 PM • Olympus D-600L... • Answered on Jun 05, 2007
External sync capacity
No, the D-500L/D-600L cameras do not have an external sync for flash. However, the D-620L includes a PC Connector for use with an external flash.
9/1/2005 9:55:46 AM • Olympus D-600L... • Answered on Sep 01, 2005
Polarizing filters
Use only a Circular Polarizing filter.
9/1/2005 9:54:56 AM • Olympus D-600L... • Answered on Sep 01, 2005
Color filters
No, color filters will impede the AWB (Automatic White Balance) circuit which will result in improper color expectations in the final image.
9/1/2005 9:54:24 AM • Olympus D-600L... • Answered on Sep 01, 2005
Microscope
No. Your camera is not compatible with a microscope, but Olympus does manufacture a DP-10 microscope digital camera system designed specifically for medical and industrial use. For more information about this, please contact the Olympus Precision Instrument Division at 800-446-5967.
9/1/2005 9:53:29 AM • Olympus D-600L... • Answered on Sep 01, 2005
My Olympus C-4000 zoom will not boot to my imac
Did it do it before? It needs Software and Drivers, it may also need Firmware for your iOS version. I am having difficulty bringing up software for it, even where it is linked. https://www.google.com/search?q=olympus+c+4000+imac+software ./..
10/15/2021 9:39:30 PM • Olympus Cameras • Answered 3 days ago
I had to by a new memory card to my Olympus Camedia C 750. I just found out that the 1GB I bought, will not work. Is tere any way of make a partion to make the camera accept the card?
Is the card you bought compatible with your camera? Older cameras cannot work with newer versions of memory cards. SD, SDHC,SDXC etc. have different form factors and old model cameras are not compatible with newer versions. If the problem is related to the card, you might like to re-format the card from a computer before inserting it in the camera and then format it again from the camera. Check and verify that before you try other solutions.
7/7/2021 3:45:25 AM • Olympus Cameras • Answered on Jul 07, 2021
My Olympus SP-560UZ shows "battery empty" with new standard (non-rechargeable) batteries. Solutio requested please.
go buy a new battery pack we will not do it for you
5/31/2021 9:32:45 AM • Olympus Cameras • Answered on May 31, 2021
Olympus OM-2 spot/program battery problem: the batteries drain in a couple of shots.
I had a similar issue with an Olympus OM4. It went in for repair but was never resolved. The batteries in my OM1-md last forever! I ended up doing the same remove the batteries after use. I can't remember the configuration, but if the LR44 are two and double stacked, you could use the Lithium equivalent. https://www.batteryequivalents.com/ag13-sg13-lr1154-sr44-303-357-a76-lr44-battery-equivalents.html ..
2/1/2021 12:48:55 AM • Olympus Cameras • Answered on Feb 01, 2021
Where I can find Manual for OLYMPUS ACCURA zoom XB70 camera
Olympus would be a possible source.
11/6/2020 7:59:54 AM • Olympus Cameras • Answered on Nov 06, 2020
Can I get rid of 3c81 error code on my Olympus E-1?
Have you tried using Google to find out what the error code actually means ? Very often, the first step in defining and correcting an error is to find out what has caused it.
6/25/2020 10:31:31 AM • Olympus Cameras • Answered on Jun 25, 2020
3answers
Which camera do you recommend - FujiFilm, Olympus or Sony?
I would recommend Sony for a best film or picture.
6/15/2020 8:46:23 PM • Olympus Cameras • Answered on Jun 15, 2020
HI!my device olympus vn8700pc has memory error what should i do to solve this problem?
This does not appear to be a camera
1/27/2020 1:27:18 AM • Olympus Cameras • Answered on Jan 27, 2020
Olympus D-600L Digital Camera Logo
Popular Tags
12 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Olympus Cameras
  • Olympus Cameras
Most Popular Question
smartmedia cards
  • Cameras
