20 Most Recent
E-Machines M5310 Notebook Questions & Answers
I CAN'T FIND MY BLUTOOTH
If your sure you have it -you will find the settings in-Control Panel-- go to START>CONTROL PANEL
How to restore emachiense727 labtop
Can you use your system recovery partition, reboot the laptop without the battery, Re boot while repeatedly tapping the F-11 key to access the recovery page or burn a windows 7 32 or 64 ISO repair disk at this location:http://maximumpcguides.com/windows-7/create-a-windows-7-system-repair-disc/
GATEWAY NV55C04B
test the adapter , try to use in another computer for to see is operative.2) IF is functioning the problem is the computer lapto the circuit power supply.3) Download or RUN the software diagnostic ONLINE from Gateway.or go to the repair Shop for fix it.God bless you
Shidownload bluetooth
/ _ \ ___________
/ /_\ \_/ ___\_ __ \
/ ' \ \___' ' \/
\____'__ /\___ >__'
_________ .__ __ .__
/ _____/ ____ ' ' __ ___/ '_'__' ____ ____ ______
\_____ \ / _ \' ' ' ' \ __\ '/ _ \ / \ / ___/
/ ( <_> ) '_' ' /' ' ' ( <_> ) ' \\___ \
/_______ /\____/'____/____/ '__' '__'\____/'___' /____ >
Hi i have an e-machine
Try windows key + (X) its a shortcut, if it doesn't show turn on bluetooth, go to device manager, and look if you have bluetooth, if so, then try to look at the Fn keys, if you still can't turn it on after pressing the button, then you may actually have no bluetooth, some laptops have that Fn key that says bluetooth but actually don't.
I am using acer emachines
im using emachine D640 i just want to ask how can i use the bluetooth? and is it ok to use the free download of
Free Emachines D640 Notebook Broadcom Bluetooth Driver (3.0) 6.3.0.6000 for Win 7 1.0 Download
I have a emachine m2350, I search visual
This is an auction for that power jack and it has free shipping which is located by clicking
here.The jack would be shipped from California. This particular guy has plenty of them so the cost would be just $6.99. I found this just by doing a search thru Ebay's website.
If I have bluetooth on my e machine desktop I
Your phone can act as a modem if its possible with phone hardware. If your computer doesnt have bluetooth built it, you can buy one online and just plug it in USB. just google USB bluetooth or ebay it
http://palmpre-hacks.com/palm-pre-hacks/how-to-tether-your-palm-pre-as-a-usb-modem/
Latop d620 worked ine but now screen is lack unless in safe mode
Now I don’t know how unplugging it or moving it would cause that problem but it does sound like you might have an issue with the refresh rate and or screen resolution at a setting that is to high for the screen to display (safe mode only loads windows core components and minimal set of drivers like basic vga driver for display which is why it probably works in safe mode)
If you are running windows XP then try the following:
Ok try hitting F8 key before XP logo appears for boot menu then select "enable vga mode" then after you get to a desktop go to display settings and lower the screen resolution and refresh rate setting
(refresh rate should be at 60hz) resolution could be different depending on which screen you have there... but try 1024x768 just to be safe then reboot into normal mode and see if it works and if it does then you can adjust the resolution to what it was before problem occurred
If you are running Windows Vista then boot from the Vista CD and select “repair my computer” and then “fix startup problems” and it should do it for you
My backlight keeps going out...and then back
Sounds like a bad LCD to me.
First check warranty status by calling manufacturer as if you work on some of this stuff yourself you voice the warranty!!
If this is in the laptop, you might want to reseat the lcd cables to make sure they are screwed down snug. If this does not fix it, replace the LCD panel.
If this is a desktop LCD i would try another one. If the other lcd works, replace the LCD.
Spyware
Go
HERE. Its online and free! I use it all the time, and its good.
You can even try
SpyBot, which is also good.
Hope that helps!
PS..dont forget to rate this as fixya if the links I provided you helped in any way.
Cheers!
IrishDruid
