20 Most Recent
Olympus Camedia D-360L Digital Camera Questions & Answers
Where can i get the
There are no software Distributions available for this device.
Although you may click
HERE for a digital version of your user manual/guide.
Click
here, for more info on available software from the manufacturer.
Camera turns on beeps turns off
Hi there. Turn on. Before it beeps, take the battery's out. This may take some practice. Now us a Qtip almost soaked in rubbing alcohol and clean the outside edges of the lenses. Put battery's back in and cycle the camera on and off. I hope this works for you. It worked for me.
Thanks
Paul
The flash will not work.
On the back you will see what looks like a little lighting bolt press key pad in that direction select flash, more you push it more choices.
If it is selected & not flashing you may have burnt out the flash bulb.:(
Hope this fixed ya! If you need more help comment back. Good Luck!
Please Rate.
Camera will not turn on.
it need to be opened by an specialist... it is sure there is nothing you can do for it without open it.
I need the Windows Vista driver for the Olympus Camedia D-360L
The camera is a serial connect camera and what we recommend for Vista users as well as our new software is to look into purchasing a smartmedia card reader that connects to USB port so that you are able to transfer images using the reader as opposed to connecting camera to PC. The camera connection is not Vista compliant.
To learn about the new and free version of Olympus Master 2 software go to:
http://www.olympusamerica.com/cpg_section/oima_softwareMaster.asp Click on 'Free Download' to register your email address to receive an email containing a link to download either the Windows or Mac version. This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x and is Vista compatible.
I got a Olympus Camedia
If your camera driver is is Windows 98 and your trying VISTA, you probably now own a rock. Vista don't like noone. If it can't autofind for software, try XP
Olympus camedia D-360L
Manual is on the CD in PDF mode
You need Adobe Reader to print it iof
Free - Simply Google for it.
CAMERA
it´s a pretty old digital camera, probably u will need to buy a new one. if u bought it few time ago, just send it to be fixed in a olympus service, it will cost u nothing.
Differences between the D-340L and the D-340R?
The Olympus D-340R is an updated model of the D-340L (which is no longer in production). They both have an SQ, HQ, and SHQ image quality setting, however, the D-340R has the additional ability to store an image file uncompressed in TIFF format. The D-340R also has the ability to magnify a portion of the image on the camera monitor LCD so that you can inspect the detail level of the picture.
The D-340R includes a total of 8 MB of SmartMedia memory (either 2 - 4 meg or 1 - 8 meg card depending on the package) whereas the D-340L includes 4 meg. The LCD monitor is slightly smaller on the D-340R (1.8" versus 2.0"). The ISO rating is also slightly different (ISO 100/200 versus ISO 60/120) which allows a broader range of picture taking situations.
Size SmartMedia™ cards
The D-220L and D-320L can use a 2, 4, or 8MB SmartMedia card. The D-340L and D-340R can additionally use a 16MB SmartMedia card.
