20 Most Recent
Olympus Camedia D-390 Digital Camera Questions & Answers
I cannot find an xD
Ebay is your best bet. There are over 630 different ones there at the moment.
I have an olympus camedia D-390 and was told at
They are correct...Olympus no longer makes the xd picture card. You might be able to find one at amazon.com This is a 7 year old camera and only 2megapixels. If I were you, I would step up to a modern camera that uses SD/SDHC cards. You will be amazed at the results you will get.
When I turn on my Olympus Camedia D-390 it flashes
You need to look at the media card onto which you are taking the photos. Possibly when you reinserted that card into the camera, you accidentaly moved the copy protection switch into the read only position.
These things are so very small that they are hard to see, or even feel, and equally difficult to know when you have moved it.
Remove the card and check the edges for this switch, to ensure that it has not been moved into read only. Then move it back to allow writing to the card.
-a.
I need a manual for my olympus d_390 camera
You can download the complete
instruction manual in PDF format by clicking this
link.
Click
here to download the
Reference Manual.
Click
Quick Start Guide.
- You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using
FixYa.
I normally use a small 32mb memory card in the
Many cameras will not read cards written on other, different cameras. There should be no problem taking the card to a store and having the pics printed or put on a disc. Or get a cord for the 390, or a card reader for your computer.
How to change resulution size
Not sure what it is you are saying here it is conflicting
Size can be chaged 320x320... 600x400 etc but the resolution is final. If the camera is 6mp or 1.3 mp that is its resolution and cannot be changed.
You can change the speed via the ISO from say 200 400 600 what this does is alter the speed of the film and improve the compression of the pixels to make a more compact picture. But does not change the resolution it remains whatever MPs it was rated at by the manufacturer.
I have just bought a new memory card for my
you need at least a 4 gb for it to read.. i just did mine too.. they are on sale right now at Target for $ 14.99, try this and let me know if this helped you good luk. tiffany in chattanooga tennessee
Write Protect
I don't know if You have all the literature for Your camera, Olympus usually puts out a short version, and a more detailed one. I am not familar with the 390, suspect some setting is incorrect. Have You tried leaving the batteries out long enough for it to return to defaults? Give it several hours, see what it does.
I cant find the on button
Open the Lens barrier to turn the camera ON and by closing the Lens barrier, you will turn it OFF.
Please let me know if that helps..
Thanks and Regards,
Srinivas
I cant delete pictures
thank you for using fixya. if you have tried deleting the items on the camera and from a computer through a memory card reader, you may want to format your memory card or use a new one because it may have been damaged or a part of it has been corrupted.
Camera won't turn on
Are they of the correct type according to the manual
If they are then contact Olympus Technical support.
USB divice not recognized
go to device manager of ur pc system.and uninstall usb drives and then scan for hardware changes and it will freshly install usb drives for you and then ur device will get detected properly.
I tried many ways to fix the problem. Someone suggesting unpluging it for 30 min. That didn't work. I downloaded the latest version of the camera driver. That didn't work. I downloaded the latest version of windows, and that didn't work.
I was running out of ideas. But I thought I might try restoring my computer to a prior date. This restore feature hasn't worked for me for 6 month. But, that day, luck was on my side.
Since I restored my computer to two weeks ago. My problem, is fixed!
D-390
The problem is that the largest xD card that your camera can support is a 256mb card without the M or H letters on it. The 1gb or 2gb card is not compatible.
