20 Most Recent Olympus Camedia D-40 Zoom Digital Camera Questions & Answers
Camedia software leaves a lot to be desired. I prefer to use a USB media reader and Google's excellent Picasa software to manage my photos.
Olympus Camedia... • Answered on May 03, 2017
it can be downloaded from downloads section in website..
Olympus Camedia... • Answered on Aug 19, 2009
Brocken sensor or catch on the cover Check the cover and see that there is a catch that goes into hole- it has probably broken off and therefore not making contact. If so thry a match stick or similar into the hole TThis will [hoepfully put the warning out even if the cover is open. If so leave it at that. If not a repair shop job- but warned big bucks just to look and parts may not be available
Olympus Camedia... • Answered on Jun 11, 2007
Instructions for downloading images from the D-40 are located at http://www.olympusamerica.com/download.
Olympus Camedia... • Answered on Aug 31, 2005
D-40 Zoom Memory Card Storage Capacity Quality Resolution # of Storable images TIFF 2272 X 1704 1 or more SHQ 2288 X 1712 5 or more HQ 2272 X 1704 16 or more SQ 2 1280 X 960 49 or more SQ 1 640 X 480 165 or more
The CD-ROM provides a full Reference Manual in PDF format on the CD-ROM. Adobe Acrobat - which is provided on the CD-ROM - is necessary to view the PDF manual. The printed manual that is included with the camera is a "Basic Manual".
With the provided Olympus CR-V3 batteries, you will get approximately 300 images under normal use. Using the Olympus Ni-MH batteries, you can get approximately 120 images per charge, and with alkaline batteries you would get approximately 30 images.
The cover opens in two positions. To completely open the lens cover for shooting images, slide the lens cover over until you hear two clicks. When the camera is on the first position, you can playback images.
The pixel mapping function checks the CCD and image processing functions. For optimized results, be sure to activate the pixel mapping function only after the camera's power has been turned off for at least one minute following shooting or playback.
Press the monitor button. The amount of images that can be stored and the selected quality mode will appear in lower-left corner of the LCD display.
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period. Always charge sets of batteries (2 or 4) together. Make sure your rechargeable batteries are all good. One defect in a set is killing for the whole set Don't use barrettes from different sets or brands together. I had one brand good NiMH batteries and a very expensive charger from the same brand. The charger destroyed all my rechargeable (more than 60 now). When I first discovered the batteries were dropping out, I stopped using the charger, but it did not prevent all batteries to die in the following months. Every time on dropped out I had to change the set. I tried using up the others by grouping the ones with the same Ri, but not longer then a few months and I had a box full to trow away. Never use a quick charger, capable of charging them within an hour or faster. Us a charger that indicates the Ri is still low enough, so you can see what batteries are bad. Check you are using a charger for NiMH batteries. I would try another set (new) because buying Alkaline is also not cheap. I used 2700 mAh and later 2600 mAh rechargeable, all dead now. since a few weeks I'm now using 2300 mHh from another brand, costing 1/5 of the "best" I had before, and they are doing great. I won't charge them with the quick charger. Never use manganese (Zinc-Carbon) batteries in electronic devices. These batteries are only to be used in flash lights.
Olympus Camedia... • Answered on Dec 07, 2016
This 14 year old camera, does not have a zoom lens. It has a 5,5 mm lens, giving it a angle of view of about a 35 mm lens of a Full frame camera. However, you should be able to zoom digital 2 times. I can't find a manual, to help you on this, but the quality will be the same as cropping into a frame on your computer. So if you do put the pictures on a computer, you also can "zoom" in to the parts you want. Be aware a 1 megapixel camera, does not offer that much of detail.
Olympus Camedia... • Answered on Oct 27, 2014
Lens is out of possition and stuck.
Olympus Camedia... • Answered on Jul 31, 2014
Put memory card into camera right way around.
Olympus Camedia... • Answered on Jul 05, 2014
Hi, any error messages?
Olympus Camedia... • Answered on Jun 20, 2014
Olympus Camedia D-40 Zoom Digital Camera Logo
12 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jax Planet
Jax Planet
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Camedia Olympus
  • Camedia Olympus
Most Popular Question
dont users manual camedia d 40
  • Cameras
