20 Most Recent Olympus Stylus Verve S / ?-181 mini S Digital Camera Questions & Answers
How to upload photos from my olympus mini s camera
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
11/29/2012 10:02:34 AM • Olympus Stylus... • Answered on Nov 29, 2012
0answers
4answers
Wont turn on properly
Ive looked all over the internet for a solution to this very common problem. This is the only one that worked for me. When you turn on the camera the green led light comes on. Hold the camera in your right hand while you turn it on and as the lense comes out, bang the camera (lens facing down)against your left palm repeatedly until you notice the led light briefly turn red then green again. You need to do this every time you turn it on.I think shaking it loosens the jarred lens. This was the only solution I could find and although I was tentative about doing more damage this way, I tried it and it works.
6/21/2009 3:16:41 PM • Olympus Stylus... • Answered on Jun 21, 2009
2answers
Cover card open when it's shut
This problem is caused by the little piece of plastic that you flip down to hold the XD card in place. It has a nipple sticking out of it that is prone to breaking off. Unfortunately, this nipple (about 1/16" x 1/8" x 1/8") holds down a little button which tells the camera that the the plastic piece has been flipped down. Once the nipple breaks off, you need to find some other way to hold the button down.
I simply took a small plastic peg from an old boardgame -- a cribbage-board peg might work -- and whittled it down to fit the opening. Remove the XD card and you'll see the small 1/16" x 1/8" rectangular opening. There's a tiny, squarish black button inside. Use a toothpick or tiny screwdriver to carefully press the button in while the camera is on, and you'll see the error message disappear.
Once you get the idea, use a tiny Phillips screwdriver to remove the plastic piece that you flip down. There are two screws to remove, two little metal retaining brackets and a tiny metal rod. Be careful not to lose any of these pieces! Then gradually whittle your piece of plastic so it fits the rectangular opening snugly, and consistently turns off the error message. Then cut it to about 1/8" in length, insert it into the opening, and reassemble the rod, brackets and screws to hold it in place.
Now the little button will always be pushed in and the camera will be functional once again. Since the XD card has its own spring-loaded "locking mechanism" (you push to insert and push to remove), the piece of plastic you flip down isn't really needed in the first place. You can save it, anyway, just for the memories....
11/3/2008 5:09:12 PM • Olympus Stylus... • Answered on Nov 03, 2008
Blue screen
turn on the camera with the lens face up
10/20/2008 2:51:11 PM • Olympus Stylus... • Answered on Oct 20, 2008
Dial on the top
This dial is the mode dial. It allows you to switch between shooting mode, recording mode (movies) and playback mode.
9/1/2005 12:45:32 PM • Olympus Stylus... • Answered on Sep 01, 2005
More telephoto zoom
The Stylus Verve has a 2x optical zoom and a 4x digital zoom, which gives you a total zoom of 8x seamless zoom. Use the shooting mode menu to activate the digital zoom feature.
9/1/2005 12:44:12 PM • Olympus Stylus... • Answered on Sep 01, 2005
Battery
The expected battery life of the Stylus Verve is about 300 frames.
9/1/2005 12:42:53 PM • Olympus Stylus... • Answered on Sep 01, 2005
Access the scene modes
From the arrow pad, select the up arrow (Scene) to access the scene modes.
9/1/2005 12:41:57 PM • Olympus Stylus... • Answered on Sep 01, 2005
HyperCrystal LCD technology
This new LCD is designed to deliver a 160° angle of viewing so it can be seen clearly from above, from the side, and from below. Where conventional LCD displays fail to deliver clear, visible pictures under bright conditions, the Stylus Verve HyperCrystal LCD is viewable even in bright sunlight at the beach or on the slopes.
9/1/2005 12:40:53 PM • Olympus Stylus... • Answered on Sep 01, 2005
Review the pictures
Using the Quick View Button Press the QUICK VIEW button. The last picture taken is displayed. Use the arrow pad to display other pictures. Press the QUICK VIEW button again when you are ready to take another picture. Using the Mode Dial Turn the mode dial to the playback option (the green arrow). Use the arrow pad to navigate to your picture of choice.
9/1/2005 12:38:37 PM • Olympus Stylus... • Answered on Sep 01, 2005
Weatherproof
The Stylus Verve weatherproofing protection is equivalent to IEC Standard publication 529 IPX4. The camera will not be damaged by water splashed from any direction. The camera can be used outside in adverse weather conditions. If you are taking pictures when the camera is exposed to rain or snow, make sure that the optical components (lens, flash) are not covered with water. Water droplets on the lens may affect image quality. The Stylus Verve is designed to operate at ambient temperatures of 32?-104?F and relative humidity 30-90%. Please note that the camera is weatherproof, not waterproof, and cannot be immersed in water. Olympus will not assume any responsibility for any camera damage caused by water getting inside as a result of misuse by the user.
9/1/2005 12:37:52 PM • Olympus Stylus... • Answered on Sep 01, 2005
PictBridge
PictBridge is a specification that allows for direct printing between various brands of digital still cameras and printers without the use of a computer.
9/1/2005 12:37:06 PM • Olympus Stylus... • Answered on Sep 01, 2005
Small bright dot
Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Locate Pixel Mapping in the camera's Mode Menu and select OK to activate it. Once Pixel Mapping is completed the Mode Menu displays. The bright dot should no longer appear in your downloaded images.
9/1/2005 12:36:13 PM • Olympus Stylus... • Answered on Sep 01, 2005
Date and time
With the camera on, press the OK/MENU button. Use the arrow pad to select [MODE MENU]. Select the [SETUP] tab and press the right arrow. Select 'time icon' and press the right arrow. Select the date format and press the right arrow. Use up or down arrows to set each item and press the right arrow to move to the next item. Press the OK/MENU button when you have finished entering the date and time.
9/1/2005 12:35:33 PM • Olympus Stylus... • Answered on Sep 01, 2005
Maintain all-weather capability
The camera loses its weatherproof capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Make sure that all the covers are closed before using the camera. Wipe any water off the camera before changing the battery or card. If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Salt-water spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. If the rubber packing becomes worn or damaged, contact your nearest Olympus service center. If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover. The rechargeable battery and other camera accessories are not weatherproof. Care should be taken when using the accessories.
9/1/2005 12:34:59 PM • Olympus Stylus... • Answered on Sep 01, 2005
Curved lines on playback screen and prints. Monitor screen is fine. Is it repairable?
Get a quote some cameras cost more to repair then to replace.
7/10/2015 1:39:57 AM • Olympus Stylus... • Answered on Jul 10, 2015
Olympus stylus 1 just froze with lens extended. I took battery and card out for 2 hrs. and still no power.
Try this, set the dial to P, then open the battery door and then press the Menu button and OK button together for about 5 seconds. If you see something in the screen like Olympus? Then press the Menu and OK button together again for another 5 seconds, this is a hard reset and hope it fixes your problem?
12/14/2014 1:29:18 AM • Olympus Stylus... • Answered on Dec 14, 2014
Olympus Stylus Verve S / ?-181 mini S Digital Camera Logo
Popular Tags
18 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Stylus Olympus
  • Stylus Olympus
Most Popular Question
battery compartment lid broken
  • Cameras
