20 Most Recent Olympus Camedia C-5500/C-55 Sports Zoom Digital Camera Questions & Answers
Embed audio notes
Since the C-5500 has audio recording capability it is possible to record brief audio notes, which become an embedded part of the image file. Open the MODE MENU and select the CAMERA tab. Toggle right to enter the CAMERA sub-menu and toggle down until you have selected the microphone icon, using the OK/MENU button. Then toggle right, select ON and press the OK/MENU button twice. The sound recording function is now enabled. About .5 seconds after the shutter is released the 4 second recording period will begin recording. You will need to point the microphone on the front of the camera toward the sound source. You can also record and record over audio notes on photos already taken. In the PLAYBACK Mode open the MODE MENU, select the PLAY tab and then select START. Pressing the OK/MENU button will start the 4 second recording period.
10/12/2013 7:00:17 PM • Olympus Camedia... • Answered on Oct 12, 2013
ALL RESET
The ALL RESET function works two ways. When it is set to ON it restores the camera to the default settings once the camera is powered off. You can still put in custom settings, but they will be reset when you turn the camera off. When it is set to OFF the camera remembers the settings you have entered. For example, if you want the camera to always start up in the 3:2 aspect ratio you would turn ALL RESET to OFF and then select the 3:2 quality setting. The 3:2 setup will be there every time you start the camera up until you set ALL RESET to ON. When ALL RESET is set to OFF the camera will accumulate all of your setting changes, so it is recommended to reset the camera occasionally.
4/20/2013 8:25:14 PM • Olympus Camedia... • Answered on Apr 20, 2013
Dear sir, I am having one
p/l call this number 020 30217602/600/700/709 mr rajesh gaonkar from data care corporation
10/25/2010 1:36:39 PM • Olympus Camedia... • Answered on Oct 25, 2010
Camedia 5500 was dropped and
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
10/21/2010 4:18:18 PM • Olympus Camedia... • Answered on Oct 21, 2010
Zoom Error
Hello
Regards
Andrea
9/27/2010 5:36:49 PM • Olympus Camedia... • Answered on Sep 27, 2010
Need free printable owners manuel for olympus
hello there,
You can find the Olympus C-series 5500 Sport Zoom here:
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1151
4/14/2010 2:43:37 PM • Olympus Camedia... • Answered on Apr 14, 2010
I have a C-5500 and the lens will not open. I
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
12/20/2009 3:00:25 AM • Olympus Camedia... • Answered on Dec 20, 2009
I want delect all photos on memory card..
Easiest way...go into the menu and scroll to "format" and follow the on-screen instructions.
11/14/2009 7:00:43 PM • Olympus Camedia... • Answered on Nov 14, 2009
Camera can't see the picture card
Card reader faulty and should be replaced ( sometimes the contacts faulty inside the reader and can be repaired without having to replace the whole reader unit) camera should go in .
9/2/2007 3:54:48 PM • Olympus Camedia... • Answered on Sep 02, 2007
I need to know how to remove the zoom lens to clean a water spot inside.
well u can, but u will need to know what are u doing, i repaired many lens when i worked in olympus, but gives lots of work.
1/19/2007 2:20:59 AM • Olympus Camedia... • Answered on Jan 19, 2007
Small bright dot
Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Locate Pixel Mapping in the camera's Mode Menu and select OK to activate it. Once Pixel Mapping is completed the Mode Menu displays. The bright dot should no longer appear in your downloaded images.
9/4/2005 9:42:24 AM • Olympus Camedia... • Answered on Sep 04, 2005
Redeye
Red-eye is actually caused by the light from the flash bouncing off the back of the retina and picking up the color red from the blood vessels. To correct this effect, follow these steps: Turn the mode dial to PlayBack Mode (green arrow) and display the image with redeye. Press OK\Menu button. Using the arrow pad, navigate to MODE MENU>EDIT>REDEYE FIX. Press the right arrow key, START will display. Press OK\Menu After {BUSY} bar displays, a screen will display with an option to cancel or save the image. ? If the option [Go] is displayed, press the OK\Menu button. This saves a corrected version of the image. ? If the option CANCEL is displayed, than the camera was unable to correct the image. Press the left arrow key to exit. This correction may not work on all pictures. If you import the original image into Olympus Master software you can also apply the Red-Eye fix located in the Edit menu. This lets you precisely pinpoint the eye area and remove the red. It even lets you remove green or blue, which can occur with animals.
9/4/2005 9:41:40 AM • Olympus Camedia... • Answered on Sep 04, 2005
Rechargeable batteries
Yes, there are two rechargeable sets, the B-80SU Ni-Mh Overnight Charger and Battery Set and the B-90SU Quick Charger and Battery Set. Each comes with four rechargeable Ni-Mh AA batteries.
9/4/2005 9:40:15 AM • Olympus Camedia... • Answered on Sep 04, 2005
External lenses
No, there are no external lenses for this model.
9/4/2005 9:39:08 AM • Olympus Camedia... • Answered on Sep 04, 2005
Images are blurry
It is possible you have the Flash Mode set to one of the Slow Sync modes (lighting bolt with the word Slow). Slow synchronization flash sets a slow shutter speed for the background exposure and fires the flash for the subject exposure. Since the shutter speed is slow, your subject should be still and the camera should be on a tripod otherwise blur can result. Since this mode should only be used when the above conditions can be met, you should use the FILL-IN FLASH (single lighting bolt symbol) mode for most situations that require a flash for correct exposure. Repeatedly pressing the FLASH MODE button will cycle through the various flash mode settings.
9/4/2005 9:38:16 AM • Olympus Camedia... • Answered on Sep 04, 2005
Manually focus the C-5500 Sport Zoom
Occasionally it is necessary to have the ability to manually focus a digital camera. A good example is shooting through the windows of a tour bus on a rainy day. The camera may choose to focus on the raindrops on the window rather than the actual subject. To enable the MANUAL FOCUS function hold down the OK/MENU button for a second or longer. In the lower left corner of the LCD screen you will see MF (MANUAL FOCUS) and AF (AUTOFOCUS) with AF highlighted in green. Use the left arrow key to select MF. You will now be able to use the up and down arrow keys to manually focus the camera. An added feature of the C-5500 is that when you are using the MANUAL FOCUS Mode you will see a magnified portion of the image in the center of the LCD screen. To get out of MANUAL FOCUS Mode, simply use the right arrow key to reset the camera to AF. Then press the OK/MENU button to return to the default functions.
9/4/2005 9:36:44 AM • Olympus Camedia... • Answered on Sep 04, 2005
SCENE Modes
The SCENE Modes allow you to rapidly and conveniently enable complex camera settings required in frequently encountered situations automatically. Such factors as ISO, f-stop, shutter speed, exposure compensation, flash mode and white balance are applied for optimum results in each of the ten SCENE Modes. The SCENE Modes in the C-5500 are: Landscape + Portrait Portrait Landscape Night Scene Sport Beach & Snow Fireworks Sunset Available Light Portrait Candle
9/4/2005 9:35:19 AM • Olympus Camedia... • Answered on Sep 04, 2005
SLIDESHOW function
You can play the images in your camera on a TV or save them to videotape by connecting the camera with the bundled Audio/Video cable. Power up the camera in the PLAYBACK Mode, press the OK/MENU button to open the menu and using the arrow keys toggle up to begin the SLIDESHOW. You can even change the playback format in the MODE MENU. Press the OK/MENU button and using the right arrow key select the MODE MENU. Toggle down to SETUP, toggle right to enter the SETUP MENU and toggle up once to PLAYBACK SETUP. When you toggle right you will be offered four playback options: NORMAL, SLIDE, FADER and ZOOM. When selected you will get the following effects: NORMAL - Each image instantaneously replaces the previous image. SLIDE - The images are sequenced by sliding from right to left. FADER - The images are sequenced via a lap dissolve. ZOOM - The images are sequenced by zooming in to black and zooming out from black.
9/4/2005 9:34:45 AM • Olympus Camedia... • Answered on Sep 04, 2005
Olympus Camedia C-5500/C-55 Sports Zoom Digital Camera Logo
Popular Tags
25 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
ZJ Limited
ZJ Limited
Marvin
Marvin
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Camedia Olympus
  • Camedia Olympus
Most Popular Question
camedia 5500 dropped
  • Cameras
