20 Most Recent Royal Procision 7050 Bagged Upright Vacuum Questions & Answers
Orange light is on
You may have a clog, which over heated the motor and it shut down. Clog could be in the hose, the dirt inlet by the brush roll and bag/filters. Some have a reset on the back, near the bottom. If not, then the over loard protector may have gone bad, could also have a motor problem.
3/22/2008 11:15:06 PM • Royal Procision... • Answered on Mar 22, 2008
My power cord doesn't retract on my Royal Lexon S20 vacuum cleaner. can I fix it myself or does it need to go in for repair
If you can get into it, it is just a coil spring that is externally or internally wound to a drum. Usually the tail of the spring breaks or comes off its anchor. Part 20 and it is discontinued! So repair only. https://www.ereplacementparts.com/royal-sr30020-lexon-s20-series-vacuum-parts-c-37589_37613_37654.html ..
11/21/2020 10:27:33 PM • Royal Vacuums • Answered on Nov 21, 2020
How to clean royal 7910 dirty water tank
Hi there! is there any way of removing the tank from the vacuum in question? i would try flushing it with water multiple times or use something like isopropyl alcohol to clean up the remains. Good Luck!
7/23/2020 10:08:54 AM • Royal Vacuums • Answered on Jul 23, 2020
My royal 4000 height adjuster-slips and dose not maintain set height. Any ideas as to repairs?
http://www.fixya.com/support/t24326835-repair_front_left_wheel_height Jul 21, 2017 - The wheels are held on by a screw behind the wheel guard, i suspect your heightadjuster has come loose off the spline, this can ... Best thing about this new service is that you arenever placed on hold and get to talk to real repairmen .... my royal 4000 height adjuster-slips and dose not maintain set height. Vax problems Why is the vacuum blowing out the ... 10 answers May 17, 2014 SOLVED: My shark cordless vac won't hold a charge 1 answer Apr 7, 2012 SOLVED: My vax vacuum has started making a ... 10 answers Feb 7, 2012 SOLVED: Sebo upright vacuum cleaner - Bag full ... 10 answers Jun 17, 2010 More results from www.fixya.com
2/27/2019 6:58:55 PM • Royal Vacuums • Answered on Feb 27, 2019
How do you replace the belt on Royal Canister carpet sweeper #4750
Follow the link to YouTube How to Replace Vacuum Belt
8/1/2018 10:51:25 PM • Royal Vacuums • Answered on Aug 01, 2018
Where does the hose attach on a royal extractor 7910 diagram?
To insert the suction hose open the cap on the top of the cleartank top nozzle assembly, insert the hose and twist. The water line pushes on to a quick release port on the side of the machine.
6/19/2018 12:02:12 PM • Royal Vacuums • Answered on Jun 19, 2018
Royal pro series carpet cleaner, new only used once. Tried today and sprays water but won't extract. Nothing in dirty water tank.
Inspect where the suction comes the machine into the water tank and through the tank to the nozzle assembly. If something isn't seated correctly or isn't working properly it could cause a suction loss.
12/1/2017 4:27:29 AM • Royal Vacuums • Answered on Dec 01, 2017
Is the Royal type b bag the same as type b micro bag?
Yes, ones standard filtration the other is microfilter material.
11/28/2017 7:18:07 PM • Royal Vacuums • Answered on Nov 28, 2017
I need an owner's manual for Royal Power Tank vacuum cleaner model 415. Can you help please?
You should try Searspartsdirect.com
9/10/2017 4:28:21 PM • Royal Vacuums • Answered on Sep 10, 2017
Royal vacuum
Need question?
1/18/2017 11:33:42 PM • Royal Vacuums • Answered on Jan 18, 2017
Royal canister Bag was full and it just stopped running?
It may have overheated. Put in a new bag.
1/3/2017 10:40:08 PM • Royal Vacuums • Answered on Jan 03, 2017
I need to fix a problem with my Royal MO88520 canister vac. It makes a popping sound as i push it related to the pop-up wheels. Also have ordered filters for it twice and keep getting wrong ones.
Hello John Slife, I searched the internet high & low (UK &USA) ... I even found your question to them about a week ago... I could not see your answer... but I can tell you I found nothing. By this time I would usually have a good idea of the color, style & options... All (I think ... is it was a 2002 model year)... Unsure results: ereplacementparts.com your number resolved to a DIRT-DEVIL BAGLESS UPRIGHT... But the two items YOU ARE INTERESTED... their Micro-Fresh perma (cylindrical) filter... and the wheel set... both show as discontinued... 2860211000 Microfresh Perma Filter Assembly My advice would be to go to their site and speak to their help... or a local vacuum shop. A good repair person can often find viable ALTERNATIVE parts based on your actual needs. FIND PARTS FAST Sorry... not much help SEARS brags a lot... I remain unimpressed but you COULD give them a try Water Filters Lawn Garden Appliance Parts
8/7/2016 12:54:46 PM • Royal Vacuums • Answered on Aug 07, 2016
I posted a question about a vaccum cleaner. Why did it wind up on Automotive questions twice?
when posting questions the secret is to read the catagory heading and if not appropriate for the question select the right catagory then ask the question with all the details as to the unit , then post it most people simply open the site and ask the question you will see a section under your post--re-categorize--- and some times people will place you post in the correct area to get more answers for you
8/7/2016 6:32:42 AM • Royal Vacuums • Answered on Aug 07, 2016
How do I attach the upholstery tool for the Royal RY7910 carpet cleaner?
Flip up the little cover on the clear nozzle on the front, insert the suction hose of the tool and twist to lock in place. Push the water hose onto the valve on the side of the machine.
2/20/2015 12:10:40 AM • Royal Vacuums • Answered on Feb 20, 2015
Royal Procision 7050 Bagged Upright Vacuum Logo
2 questions posted
Top Royal Vacuums Experts
john h
Are you a Royal Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Royal Vacuums
  • Royal Vacuums
Most Popular Question
orange light
  • Vacuums
