20 Most Recent Acer Aspire 3810T 4810T 5810T Questions & Answers
press Fn + F3 and it will pop up a box that you can switch either your WLAN or Bluetooth
if the switch doesnt come up check the BIOS setting to see if the Bluetooth was disabled from there
Acer Aspire... | Answered on Feb 06, 2016
Nor do I think you will find the solution here as we can not read your mind .
Acer Aspire... | Answered on Jan 24, 2015
sounds like to me you have a bad connection in the battery terminals. try cleaning the contacts with a Emery stick.
Acer Aspire... | Answered on Nov 09, 2014
Try these steps.. Click start button, type "mouse" on Search Programs and Files, click "mouse" under control panel. In mouse properties options....as you an see the touch pad driver tab? click it. Choose or click option button and you can enable the right and left click button. About the keyboard problem,,,,,go to device manager, right click the standard PS/2 keyboard..uninstall it. Windows restarting and the keyboard driver will re install automatically.. check if the keyboard works fine.
Acer Aspire... | Answered on Sep 10, 2014
Try installing the touchpad driver from here http://www.helpjet.net/files-Acer-Aspire-4810T.html#ATouchpad
Once you are done restart your Acer and see what happens.
If this doesnt resolve the issue it may be a problem with the hardware in which case you may need a new touchpad. otherwise just use a mouse as a fix either temporarily or if it turns out to be to expensive to fix.
Acer Aspire... | Answered on Aug 27, 2014
Unfortunately then you can not reset the machine yourself. In fact even with the right password XXXXX would not work. When three incorrect BIOS passwords are used on the machine it locks up and need to be manually reset. This can only be done by its at an authorized service center or if mailed in to them.
Acer Aspire... | Answered on Aug 23, 2013
Hi!
Is there any lights or the LED lits? Try to plug your laptop on a monitor. It could be the LCD is damage
Acer Aspire... | Answered on Aug 22, 2012
You can start the Recovery from outside windows by holding down the ALT key and tapping F10 repeatedly
on startup. When the recovery loads you will be prompted for a password.
This should have been set by the customer if they have been into the Acer Recovery Management software previously.
If they have forgotten the password or you wish to clear the password you need to boot off the recovery disk that should have been created.
More Information
From the Acer toolbar at the top of the desktop click on the disk icon
Setup a password if requested.
After clicking on setup you need to click Create Password to continue.
Create a password and add a password hint (strongly recommended).
You now have the option of restoring from a previous Windows Vista backup or you can start the Acer recovery process.
The recovery is started by clicking Restore at the bottom of the window.
Further types of recovery are now presented.
Choose Restore system to factory default if you wish to run the hard drive based recovery and return your Acer computer back to it's original factory default state.
Note: The factory default recovery will wipe ALL data from the computer so ensure important data has been saved to disk before proceeding.
Enter the password that was previously set.
Confirm you wish to run the recovery process.
After confirming you wish to run the recovery process the computer will restart and restore all the original files
Complete the Out of Box Experience when prompted
After a couple of restarts the computer will run through restoring the preinstalled software that came with your computer and then be ready to use
hope this helps
Acer Aspire... | Answered on Jul 28, 2012
click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors or you could tick one box and wait until its finished then return and tick the other box
then select check now,start should schedule this task when restart
it will only schedule on restart if its the Primary hard drive with an operating system on it
do not do anything while the chkdsk utility is in progress any input may damage your computer
for USB drives click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
hope it helps
Acer Aspire... | Answered on Jul 06, 2012
It may require you to download and install the proper drivers in order to use your bluetooth device.
Go to http://support.acer.com/product/default.aspx?modelId=1148 and download the bluetooth drivers for your operating system.
Reply back if you have issues.
Acer Aspire... | Answered on Dec 24, 2011
Sounds to me like you may need a new battery.
Acer Aspire... | Answered on Jul 26, 2011
You can circumvent BIOS passwords by using the error codes for failed entry.
here is a guide
Acer Aspire... | Answered on Mar 04, 2011
battery problems aren't fixed. Once a battery give problems, it has to be replaced. This problem looks like a battery problem, it is kind of obvious.
But before you make any replacement, do you know of anyone that uses, exactly the same Acer model as yours? If yes, test the persons battery on your laptop and one it functions well, then it means you will end up buying another battery Also, test the adapter because they are daisy sometimes. An adapter could be faulty sometime and you might mistake it for the battery. This is why you need to test the battery and adapter with another laptop and vise versa .
Batteries are not repaired or fixed, but it can be replaced.So verify first, to actually be sure your battery is bad, and once that is done, you can proceed for the replacement.
Lastly, if you don't know where to get a battery replacement, please let me know so that I could direct you to one or two sites that you can order the battery from.
I hope you understand the above.
Good luck.
Acer Aspire... | Answered on Jan 15, 2011
Statement or question, if the latter, what is it.
Acer Computers &... | Answered on Aug 05, 2020
You can use a DVD copy program like Nero if there is one on your computer.
Nero checks to make sure that you DVD isn't copy protected before it copies it. If it is you won't be able to copy it.
Windows XP or Vista does't provide DVD copy software built into Windows.
Acer Computers &... | Answered on Jun 30, 2020
*try it in other system
* change the cable of dvd
Acer Aspire 3810T 4810T 5810T Logo
23 questions posted
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
View Most Popular
  • Acer Computers & Internet
Most Popular Question
use bluetooth
  • Computers & Internet
