20 Most Recent Polaroid PhotoMax PDC 1300 Digital Camera Questions & Answers
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Once the pictures are on your computer, you can treat them as you do any other file. Obviously, the procedure for inserting a picture into a document depends on the program you're using to create/manipulate the document.
Polaroid... • Answered on Apr 11, 2011
This message appears because Windows XP did not originally support the USB 2.0 specification. However, as of May 2002, the final release version of the Microsoft USB 2.0 drivers for Windows XP is available at the Windows Update Site. The driver is designated Microsoft USB Driver Version 5.1.2600.0.
Polaroid... • Answered on Sep 21, 2005
The cause of this problem can be traced to both the computer's hardware configuration and Windows 98SE (Second Edition). PhotoMAX cameras and other devices featuring USB (Universal Serial Bus) connections may not work with computers running Windows 98 Second Edition and equipped with the following computer hardware: * an AMD processor (350 MHz or higher) * VIA Technologies USB Host Controller or SiS 7001 USB Host Controller To find out what USB Host Controller is on your system: 1. Click Start > Settings and choose Control Panel. 2. Double click the System icon. 3. Choose the Device Manager tab. A window similar to the one shown below appears. 4. Expand the Universal Serial Bus controllers listing by clicking on the "+" sign next to the listing. 5. Note the type of host controller in the listing. The example above shows the SiS 7001 PCI to USB Open Host Controller.
Polaroid... • Answered on Sep 14, 2005
Yes -- with some minor modifications, you should be able to use your PDC 1300 with a computer running Windows XP.
First check whether your speaker has a slot for SD card if it is present then plug the SD card into the slot
Polaroid Cameras • Answered on Jan 16, 2021
This camera is known for that. Save your money and buy something with rechargeable battery
Polaroid Cameras • Answered on Feb 19, 2020
Is the memory card full? If thats not the problem, take the card and batteries out so it will reset, Make sure it is set on the correct mode. Then try again.
Polaroid Cameras • Answered on Nov 21, 2019
First thing is to check that the batteries are correctly inserted. If they are, then it seems likely that you are not using sufficiently high powered batteries - are you using those recommended by the manufacturer ?
Polaroid Cameras • Answered on Oct 03, 2019
When mine wouldn’t close it is the battery is not in right. Hope this helps.
Polaroid Cameras • Answered on Jul 25, 2019
Search for on google, input as above from end of user.
Polaroid Cameras • Answered on Jun 18, 2019
Polaroid PhotoMax PDC 1300 Digital Camera Logo
6 questions posted
Top Polaroid Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
View Most Popular
PhotoMax Polaroid
  • PhotoMax Polaroid
Most Popular Question
error code 28 windows xp usb 2 0
  • Cameras
