20 Most Recent
Polaroid PhotoMax PDC 1100 Digital Camera Questions & Answers
as for as i now there are no xp drivers for this camera
Polaroid...
Answered
on Aug 16, 2010
Normally this is caused by not having installed the driver for the camera, the driver is located on the software disk that came with your camera, once installed the computer will recognize your camera, if you do not have the disk, try looking on the web in the manufacturers site in the support section to see if there is a driver download for your camera.
Polaroid...
Answered
on Feb 14, 2010
Try using a separate card reader to download your pictures.
Polaroid...
Answered
on Sep 15, 2009
Windows Me and 2000 -
A new camera TWAIN driver (version 4.1e) compatible with Windows Me and 2000 is now available for download. The new TWAIN driver will allow photo transfer using most image viewing or editing programs that are TWAIN compatible.
Windows NT4 -
No TWAIN driver is available for use with Windows NT4.
However, the PDC 1100 accommodates a removable CompactFlash memory card (maximum 128MB) for storing images. When used with a Windows NT4-compatible CompactFlash card reader, images can be dragged and dropped from the camera's memory card to any location on your computer's hard drive.
Polaroid...
Answered
on Sep 21, 2005
You can use any size Type 1 CompactFlash memory cards, up to a maximum of 128MB.
Polaroid...
Answered
on Sep 14, 2005
The cause of this problem can be traced to both the computer's hardware configuration and Windows 98SE (Second Edition).
PhotoMAX cameras and other devices featuring USB (Universal Serial Bus) connections may not work with computers running Windows 98 Second Edition and equipped with the following computer hardware:
* an AMD processor (350 MHz or higher)
* VIA Technologies USB Host Controller or SiS 7001 USB Host Controller
To find out what USB Host Controller is on your system:
1. Click Start > Settings and choose Control Panel.
2. Double click the System icon.
3. Choose the Device Manager tab. A window similar to the one shown below appears.
4. Expand the Universal Serial Bus controllers listing by clicking on the "+" sign next to the listing.
5. Note the type of host controller in the listing. The example above shows the SiS 7001 PCI to USB Open Host Controller.
Polaroid...
Answered
on Sep 14, 2005
First check whether your speaker has a slot for SD card if it is present then plug the SD card into the slot
Polaroid Cameras
Answered
on Jan 16, 2021
This camera is known for that. Save your money and buy something with rechargeable battery
Polaroid Cameras
Answered
on Feb 19, 2020
if the line is present on all the pictures, then the display has a fault.
Polaroid Cameras
Answered
on Jan 06, 2020
Is the memory card full? If thats not the problem, take the card and batteries out so it will reset, Make sure it is set on the correct mode. Then try again.
Polaroid Cameras
Answered
on Nov 21, 2019
First thing is to check that the batteries are correctly inserted. If they are, then it seems likely that you are not using sufficiently high powered batteries - are you using those recommended by the manufacturer ?
Polaroid Cameras
Answered
on Oct 03, 2019
