20 Most Recent Polaroid iZone 300 Digital Camera Questions & Answers
Either the battery is not charged or no good or the camera has died on you. Will the camera work off of the charger? It should. if it is good.
Polaroid iZone... | Answered on Oct 13, 2015
Go to polaroid.com, select digital cameras and follow the prompts. Eventually you will be able to select the manual for the izone300-301. Peace
Polaroid iZone... | Answered on Jul 25, 2014
Hello. When a camera will not hold a charge you must replace the rechargeable battery. Take your camera into a local camera shop along with the charger and have them test both the battery and the charger. This is generally a free service. Joe
please rate my answer as very helpful. thank you.
Polaroid iZone... | Answered on Jul 25, 2013
I found instructions posted on the internet that showed the reset button, I pushed that button and everything was back to normal.
Polaroid iZone... | Answered on Sep 27, 2011
You probably need to format your card. Look thru the menu on your camera...there should be a place on the help menu, which allows you to format your card.
Polaroid iZone... | Answered on Aug 21, 2011
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Polaroid iZone... | Answered on Jun 24, 2011
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Polaroid iZone... | Answered on Apr 09, 2011
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Polaroid iZone... | Answered on Apr 04, 2011
The computer is does not deplete the cameras current. However, the device deos not charge from the computer. Power insert the device into a power outlet with power charger.
Polaroid iZone... | Answered on Feb 10, 2011
Cameras Logo
100 questions posted
Top Polaroid Cameras Experts
Ekse
Marvin
Marvin
LP
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
View Most Popular
Polaroid Cameras
  • Polaroid Cameras
Most Popular Question
will not turn
  • Cameras
