20 Most Recent Polaroid PhotoMax Fun Flash 820 Digital Camera Questions & Answers
You don't need the cable or the cd. You can download free photo editing software and buy a card reader ( $10.00 & up).
Polaroid... • Answered on Dec 07, 2013
These ar egenerally available from most PC and Electronics stores and online from eBay. Take your camera with you to or quote the model no or type of connector if buying online to make sure you get the right connection for the Polaroid camera.
Polaroid... • Answered on Nov 10, 2009
u mean the drivers ... ??? u can download it in polaroid website!!
Polaroid... • Answered on Apr 08, 2008
Microsoft defines Kernel32 errors as follows: "The Kernel32.dll file is a 32-bit dynamic link library file that is found in Windows 95, Windows 98, or Windows Millenium Edition (Me). The Kernel32.dll file handles memory management, input/output operations, and interrupts. When you start Windows, Kernel32.dll is loaded into a protected memory space so that other programs do not take over that memory space. On occasion, you may receive an invalid page fault (IPF) error message. This error message occurs when a program tries to access the Kernel32.dll protected memory space. Occasionally, the error message is caused by one particular program, and other times the error message is provoked by multiple files and programs."
Polaroid... • Answered on Sep 21, 2005
The "Camera not connected" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
The Fun! Flash 820 was designed to be used with Windows 95/98 or Me. Testing has shown that photo downloading does not work with the Windows XP platform.
There are two basic ways to work around this situation: * Use a PS/2 mouse instead of a serial mouse. Using a PS/2 mouse will free up your serial port so that you can connect the camera to the computer. Check the computer's documentation to see if this type of mouse is available for your system. * Enable MouseKeys on your computer. MouseKeys allows you to use the numeric keypad to move the mouse pointer and to click, double-click and drag. After enabling MouseKeys, you can disconnect the serial mouse and connect the camera to the computer. Click Here to see an animated demonstration, or follow the instructions below. To enable MouseKeys: 1. From the Windows toolbar, select Start > Settings > Control Panels. 2. Double-click the Accessibility Options icon. 3. Select the Mouse tab. 4. Select Use MouseKeys and change settings, if desired. 5. Click OK.
Polaroid... • Answered on Sep 14, 2005
First check whether your speaker has a slot for SD card if it is present then plug the SD card into the slot
Polaroid Cameras • Answered on Jan 16, 2021
This camera is known for that. Save your money and buy something with rechargeable battery
Polaroid Cameras • Answered on Feb 19, 2020
Is the memory card full? If thats not the problem, take the card and batteries out so it will reset, Make sure it is set on the correct mode. Then try again.
Polaroid Cameras • Answered on Nov 21, 2019
First thing is to check that the batteries are correctly inserted. If they are, then it seems likely that you are not using sufficiently high powered batteries - are you using those recommended by the manufacturer ?
Polaroid Cameras • Answered on Oct 03, 2019
Polaroid PhotoMax Fun Flash 820 Digital Camera Logo
10 questions posted
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Jax Planet
Jax Planet
Fahr Quad
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
View Most Popular
PhotoMax Polaroid
  • PhotoMax Polaroid
Most Popular Question
no interface cable cd rom
  • Cameras
