20 Most Recent Polaroid PhotoMax PDC 700 Digital Camera Questions & Answers
Need new software for PDC 700 for windows 7
Windows 7 has a builtin decoder program for all camera multimedia devices. Navigate through the list of available programs to ascertain the media program that is compartible to the camera. usually the camera should be connected to the computer for detection of any compartibility be achieved. Capture media with camera, connect the camera with USB cables to the computer. Also, cameras that have storage media would require to insert the media into computers that are media component compartibel to attain multimedia transfer.
2/9/2011 6:58:21 PM • Polaroid... • Answered on Feb 09, 2011
I want a memory card for my polaroid pdc 700 what
Compact Flash, or CF, up to 2GB in size.
1/31/2011 5:45:17 AM • Polaroid... • Answered on Jan 31, 2011
Where do I get the
Polaroid PhotoMax PDC 700 Digital Camera driver is available to download .To download it for free click here
8/30/2010 4:50:34 PM • Polaroid... • Answered on Aug 30, 2010
Polaroid PDC 700 memory card error message
According to the actual manuel and other info on this,  it will only hold as high as a 48x.
10/16/2007 11:46:27 AM • Polaroid... • Answered on Oct 16, 2007
Getting great pictures
Here are some tips for taking great pictures with your PDC 700 camera: * Keep the sun behind you or at your side. Avoid having the sun directly overhead. * Use the Flash On setting if there is a light behind your subject. * In low light conditions, use a tripod to avoid camera movement during exposure. * When possible, take pictures when the temperature is between 13C (55F) and 35C (95F). Temperatures outside this range can affect battery performance. * Keep the subject within the flash range of 18 in. to 10 ft. (0.45m to 3m.) * Avoid shooting toward reflective objects, which can result in "hot spots" in your pictures. If you cannot avoid shooting toward reflective objects, use the Flash On setting . * Periodically clean the lens, the LED area on the front of the camera, and the LCD display on the back of the camera. Use a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues.
9/21/2005 3:21:48 PM • Polaroid... • Answered on Sep 21, 2005
"Connection failed" -- USB connection
The "Connection failed" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue. Fortunately, the most common causes of this error message are also the most easily identified: * Make sure that the computer's operating system is USB compatible. Microsoft Windows 95 and NT operating systems are not compatible with USB technology. (In addition, PhotoMAX and PhotoImpression software cannot be installed on Windows NT systems.) If you have an incompatible operating system, you must upgrade to Windows 98, Me or 2000 to use a USB connection. Your computer must also have the appropriate USB connectors. NOTE: This camera cannot make a USB connection with a computer running Windows XP. * Make sure that the camera power is on. Follow the camera instructions to turn the camera on. Some cameras conserve battery power by turning off automatically after a few minutes of inactivity. If necessary, install new batteries or connect the camera to AC power (if it has an AC power adapter). * Make sure that the camera is correctly set to access images. Make sure the camera is turned on and that its mode dial (if it has one) is correctly set for transferring pictures to the computer. Refer to the camera user guide for more information. * Make sure that the camera cable has not been damaged or become disconnected from the computer. Confirm that both of the connectors are firmly attached. Check the cable for breaks, kinks or other defects, and check the connectors for bent or broken pins. If the cable is broken or kinked, obtain a new cable.
9/21/2005 3:15:21 PM • Polaroid... • Answered on Sep 21, 2005
Memory card format.
The Polaroid PDC 700 digital camera accommodates an optional, Type 1 ATA compatible CompactFlash memory card up to 48MB. When an unformatted memory card is installed in the camera, it is automatically formatted when the camera is powered on. WARNING: Once you format the flash memory or format a memory card, all images are erased and cannot be retrieved - they are gone forever! Before you format (erase) the flash memory or format a memory card, transfer the images to your computer.
9/21/2005 3:08:02 PM • Polaroid... • Answered on Sep 21, 2005
Battery life?
Using the LCD viewfinder to compose images drains the power capacity of alkaline batteries very quickly. Instead, use the Optical viewfinder to compose your images. Under normal operating conditions using the Optical viewfinder, a set of AA-size alkaline batteries should last for about 35 images. Additional tips for extending battery life: * Use the AC adapter to review images on the LCD. * Use the AC adapter to review images on your TV. * Disable Quick Review mode. * For longer battery life, use one of the following types of batteries: o High capacity alkaline (a new product on the market as of Jan 2000) o Lithium o NiMh (Nickel Metal Hydride) rechargeable. o NiCd (Nickel-Cadium)
9/21/2005 2:49:25 PM • Polaroid... • Answered on Sep 21, 2005
Memory card?
The PDC 700 digital camera has 4 MB of internal flash memory on which to store images. An optional ATA-compatible Type 1 CompactFlash memory card gives your camera substantially more memory, allowing you to store more images or images of higher quality. images captured on the CompactFlash card can be downloaded using the same method as you use to download photos from the internal memory.
9/21/2005 2:48:31 PM • Polaroid... • Answered on Sep 21, 2005
"Connection failed." -- Serial connection
The "Connection failed" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
9/21/2005 2:43:07 PM • Polaroid... • Answered on Sep 21, 2005
USB connection problem using Windows 98 Second Edition.
The cause of this problem can be traced to both the computer's hardware configuration and Windows 98SE (Second Edition). PhotoMAX cameras and other devices featuring USB (Universal Serial Bus) connections may not work with computers running Windows 98 Second Edition and equipped with the following computer hardware: * an AMD processor (350 MHz or higher) * VIA Technologies USB Host Controller or SiS 7001 USB Host Controller To find out what USB Host Controller is on your system: 1. Click Start > Settings and choose Control Panel. 2. Double click the System icon. 3. Choose the Device Manager tab. A window similar to the one shown below appears. 4. Expand the Universal Serial Bus controllers listing by clicking on the "+" sign next to the listing. 5. Note the type of host controller in the listing. The example above shows the SiS 7001 PCI to USB Open Host Controller.
9/14/2005 1:35:48 PM • Polaroid... • Answered on Sep 14, 2005
Can I use the PDC 700 with Windows Me?
The PDC 700 camera TWAIN driver is not 100% compatible with Windows Me because it does not support USB downloads. No new driver software is available from Polaroid -- however, a compatible TWAIN driver is available from a third-party source. The Pretec DC-800 is the functional equivalent of Polaroid's PDC 700. Pretec's DC-800 Setup Disk for Windows 95/98/ME/2000 is available for download at its online Driver Download Center. Testing done by Polaroid has shown that this driver works with the PDC 700 using the listed operating systems, including Windows Me. When accessing the camera with image editing software compatible with the computer's operating system, the camera driver appears as Digital Camera 1024X768 Driver.
9/14/2005 12:46:34 PM • Polaroid... • Answered on Sep 14, 2005
Can I use the PDC 700 camera with Windows XP?
Yes, you can use the camera with Windows XP, but you will no longer be able to use a USB port to download your photos. Only serial port downloads are supported under Windows XP for the PDC 700 camera.
9/14/2005 12:21:18 PM • Polaroid... • Answered on Sep 14, 2005
0answers
Polaroid iSO48 Waterproof 16MP 4x Optical Zoom Digital Camera. I have an issue I think, when I watch a video that was recorded with the camera? It sounds like a constant "pip pip pip".
Question edited for clarity. This noise is more likely coming from the whatever is playing the video that than the camera recording itself. I have seen on old VCR machines. Play the video on something else to test.. https://www.google.com/search?q=Polaroid+iso48+video+makes+noise ..
2/25/2024 11:22:01 PM • Polaroid Cameras • Answered on Feb 25, 2024
Polaroid PhotoMax PDC 700 Digital Camera Logo
Popular Tags
16 questions posted
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
View Most Popular
PhotoMax Polaroid
  • PhotoMax Polaroid
Most Popular Question
want memory card polaroid pdc 700
  • Cameras
