20 Most Recent
Polaroid Ion 230 Digital Camera Questions & Answers
Can't find my installation disk.
You could try to look it up on Polaroid.com
Most computers newer than 10 year old have plug and play. Which means they automatically recognize new things plugged in and make the necessary drivers automatically.
(Make sure you have an internet connection when you plug it in, because your PC may download driver materials automatically)
Try plugging in the camera and wait to see what the computer does. If a small window opens at the lower right saying device or camera was installed correctly, you will then be able to access the camera like just another hard drive on your system.
Open My Computer or Explorer and it will appear with all the other hard drives like:
OS (C:)
RECOVERY( D:)
DVD/CD-RW-Drive (E:)
and so on...
the camera will appear as another new drive (letter:)
You can then open and navigate the folders on the camera select (highlight) photo's you wish to keep and drag them to the folder on your C: drive where you store pictures, or for most people: My Documents / My Pictures.
If you are on a MAC computer good luck, I don't know if they have plug and play?
I personally don't ever load installation disks as long as my computer recognizes the camera or device. Extra software on installation CD's take up more space and often ad stuff to your computers start up which then makes your computer slower by running the software all the time. With plug and play you only use computer processing as needed (when it's plugged in)
L8ers
Green light flashing on Polaroid iE 6035
The green light flashing on your Polaroid iE 6035 camera typically indicates that the camera is in standby mode or that it is charging. If the camera is not charging, it could be a sign of a problem with the battery or charging mechanism. If the green light continues to flash even after charging, it may be necessary to take the camera to a professional for repair or to have the battery replaced. Before seeking professional help, you can also try resetting the camera or removing and reinserting the battery to see if that resolves the issue.
