20 Most Recent
Sharper Image AM/FM Shower Companion Radio with Aluminum Cone Stereo Speakers - Gray and Blue (SI695... Boombox Questions & Answers
Lost the directions to my SI Shower Companion
Do not turn the radio on. Then depress the "mode" button and yo will see all the questions, including time, date, etc. to respond to. Either channel + or - or Tuning + or - (I don;t recall which), will get you the numbers you need, pressing "mode" again will get you to the next module or out entirely.
Cant get it to power up
I had exactly the same problem. Here is how I resolved it. 1. There is a reset button inside the battery compartment, in the center, between the C cells. Try pushing it with a paper clip or similar item. 2. If that doesn't work, replace the C cells. 3. If that doesn't work, try replacing the lithium backup battery. It is located between the C cells, in a compartment with an arrow. 4. I finally did all three at the same time, replacing the C cells, lithium battery, and resetting the system. The radio has worked fine for two days now. Good luck.
Replacing batteries in Sharper Image wireless specker
Usually, you can use the + and - signs within the battery compartment to guide your placement of the batteries. But you want to make sure that the batteries are compatible with your speakers, so calling Sharper Image to verify this would be a good move.
Thank you
My sharper image touch mp3 player won't play .avi files.
The problem is that the player of this MP3 has a corrupted program. If this device could play .avi and .mp4 before, you need to contact the manufacturer and have them reloaded the program.
But if you haven't tried playing .avi and .mp4 file format before, then refer to the user manual to verify it this device supports those video file format.
Thank you!
