20 Most Recent Philips LX3900SA System Questions & Answers
0answers
0answers
0answers
0answers
Hallo, here Andrea From Italy. Now o
Since U are using a universal remote control, these are bound to happen. Please try another code using the same universal remote control or get the original one. Use the auto-search function for your device on your universal remote control. I think you first: 1. Hold the set key, then the power button 9a red light should be observed at this time on the remote control), 2. Release the buttons, and the light will start to blink at intervals (Make sure at this time, the remote is pointed to the device sensor,and monitor this closely). 3. Once it is able to put your device off, quickly press the set button. Then 'on' you go. Enjoy.
4/21/2011 3:04:45 AM • Philips LX3900SA... • Answered on Apr 21, 2011
How do I make my
Hi!
Kindly follow the instructions here... Note that 0 (zero) is the "region" you're looking for!
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck & best regards,
Pelu.
3/31/2011 11:20:41 AM • Philips LX3900SA... • Answered on Mar 31, 2011
I am purchase last 4.5
if your completely against their products i wouldn't go for an x-ray anytime soon it's not plillips as much as just getting a lemon in a bunch of apples and if you got close to 5 years out a boxed-theater set-up i'd say you did ok learn from it and get a set-up more apt to fit what you felt that system lacked in the sound department i did ok in the local classifieds and built a system worth about 3000$ for under 750$ by finding pieces at budget deals and always checking user reviews for items i am going to purchase because 1000 opinions usually lead to find the good and bad points of a product hope this helps and sorry to hear your bad luck with your equipment
11/22/2010 4:04:56 PM • Philips LX3900SA... • Answered on Nov 22, 2010
FM WON'T RECEIVE STATIONS
Make sure that the antenna is properly hoked up. In most cases it just come loose, happens on my Pioneer system all the time. And if you have pets or it gets nudged or bumped frequently this can happen. If that still doesnt solve the problem I would recommend buying a new antenna available at most electronics stores.
11/4/2009 6:15:58 PM • Philips LX3900SA... • Answered on Nov 04, 2009
NEW DVD DRIVE AS MINE DOES NOT WANT TO PLAY NO
run ur pc in safe mode and insert dvd disc and then use this around 2min and then start ur window normally and ur dvd drive working
5/7/2009 7:44:11 AM • Philips LX3900SA... • Answered on May 07, 2009
2answers
Why is the door of the CD transport on my philips cdr 796 just keep opening even with a CD inserted?
Replace the loading belt and check the timing.
7/2/2021 10:22:23 AM • Philips Audio... • Answered on Jul 02, 2021
Philips sw3440/37 audio inputs D-sub 15 connector pinout
b7ecc65e-ea58-419e-ac45-eaa319918397.jpg this is what i have on mine i used a 3.5 mm jack as an INPUT and i also have a set of female RCAs next i will be replaceing the plugs for speakers and putting standard speaker terminals
5/2/2021 4:27:35 AM • Philips Audio... • Answered on May 02, 2021
How to connect with mobile PHILIPS MODEL NO DSP 3300
This music system is a basic setup so your choices are limited. You could try using a cable connection. The type you need is a "phono jack plug" to "3.5mm jack plug" cable. They are usually very cheap and most TV and Technology Stores will keep them in stock. The cable has different styles of connector at each end. One end is the same as the round red and white plugs at the top of the photograph and the other end is a standard headphones connector. Plug the red and white pair into an 'Audio In' position on the back of the system and the other end into the headphone hole on your mobile phone. (Try the position above the two already in the system). Select the channel on the system for that connector and press play on your mobile device.>
11/29/2020 2:16:49 PM • Philips Audio... • Answered on Nov 29, 2020
2answers
How to connect a Bose soundbar to a Philips 52in tv without a HDMI ARC or Optical output
For connecting a soundbar to the TV, you have several ways. If you don't want to use the HDMI option, you need to go high-tech with a wireless connection. Another way is to use Aux or RCA cables.
11/10/2020 6:55:45 AM • Philips Audio... • Answered on Nov 10, 2020
Philips LX3900SA System Logo
14 questions posted
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Audio Players & Recorders
Most Popular Question
make
  • Audio Players & Recorders
