20 Most Recent Philips Magnavox MRD-250 System Questions & Answers
4answers
Where can i get a fm antenna
have you tried Maplins?
11/25/2014 8:41:02 PM • Philips Magnavox... • Answered on Nov 25, 2014
Stock password in preferences? Won't play movie without a password.
The default password is 3308. If this doesn't work I suggest you do a factory reset on the unit. See page 28 and 29 of the manual.
10/27/2012 12:20:45 AM • Philips Magnavox... • Answered on Oct 27, 2012
2answers
Won't play dvd's
The DVD portion of the laser is failing. A replacement (if available) should be about $50-$80 and most shops would charge about $50-$75 to put it in.
6/15/2008 6:30:29 AM • Philips Magnavox... • Answered on Jun 15, 2008
Power middle speaker
Yes, you must hook the center speaker to a tuner, or it will not work.
2/19/2008 4:19:21 AM • Philips Magnavox... • Answered on Feb 19, 2008
2answers
Philips System 500 Hi-Q dictation machine squeaks on record.
If your new tapes squeak while recording, there could be misalignment in the record path or it could be worn. Curious that no tapes were supplied with the machine. Perhaps you can take the machine to the vendor to demonstrate operation with squeaking.
10/16/2021 7:40:03 AM • Philips Audio... • Answered on Oct 16, 2021
When I push "record" on Philips CkDr760 recorder t the display shows "no analog."
many older units will not work for digital signals
9/9/2021 6:40:37 PM • Philips Audio... • Answered on Sep 09, 2021
Need circuit diagram for philips
I have a service manual pdf there isn't any way to attach it to this message. Give me your email address and I'll send it to you. Or if you have some other way to send it electronically we can do that.
8/13/2021 7:54:23 PM • Philips Audio... • Answered on Aug 13, 2021
2answers
Why is the door of the CD transport on my philips cdr 796 just keep opening even with a CD inserted?
Replace the loading belt and check the timing.
7/2/2021 10:22:23 AM • Philips Audio... • Answered on Jul 02, 2021
Philips sw3440/37 audio inputs D-sub 15 connector pinout
b7ecc65e-ea58-419e-ac45-eaa319918397.jpg this is what i have on mine i used a 3.5 mm jack as an INPUT and i also have a set of female RCAs next i will be replaceing the plugs for speakers and putting standard speaker terminals
5/2/2021 4:27:35 AM • Philips Audio... • Answered on May 02, 2021
How to connect with mobile PHILIPS MODEL NO DSP 3300
This music system is a basic setup so your choices are limited. You could try using a cable connection. The type you need is a "phono jack plug" to "3.5mm jack plug" cable. They are usually very cheap and most TV and Technology Stores will keep them in stock. The cable has different styles of connector at each end. One end is the same as the round red and white plugs at the top of the photograph and the other end is a standard headphones connector. Plug the red and white pair into an 'Audio In' position on the back of the system and the other end into the headphone hole on your mobile phone. (Try the position above the two already in the system). Select the channel on the system for that connector and press play on your mobile device.>
11/29/2020 2:16:49 PM • Philips Audio... • Answered on Nov 29, 2020
2answers
How to connect a Bose soundbar to a Philips 52in tv without a HDMI ARC or Optical output
For connecting a soundbar to the TV, you have several ways. If you don't want to use the HDMI option, you need to go high-tech with a wireless connection. Another way is to use Aux or RCA cables.
11/10/2020 6:55:45 AM • Philips Audio... • Answered on Nov 10, 2020
Hi, I have philips D573 mini hi-fi music system. Can I connect my phone to it? OR Do I need an amplifier to do it?
Hi Darshan Ganesh, you can connect your phone to your Philips D573 You must connect the audio audio output of your phone (headphone output) to the Philips Auxiliary input on the rear panel Hola Darshan Ganesh, puedes conectar tu telefono a tu philips D573 Debes conectar la salida de audio de audio de tu telefono(salida de auriculares) a la entrada Auxiliar del Philips en el panel trasero https://www.philips.ae/c-p/FWD573_98/-
10/22/2019 4:55:40 AM • Philips Audio... • Answered on Oct 22, 2019
I bought a used Philips soundbar and i can not get it to work....any suggestions.?
Hello Steven Schofield, indicates the model of the sound bar you are commenting on, in order to find the best possible solution You should claim who sold you the bar I wait your answer Regards Franco Dosil Hola Steven Schofield, indica modelo de la barra de sonido que estas comentando, para poder encontrar la mejor soluci?n posible Deber?as reclamarle a quien te vendi? la barra Espero tu respuesta Saludos Franco Dosil
10/8/2019 11:12:17 PM • Philips Audio... • Answered on Oct 08, 2019
3answers
The wire colors from tone
Here is a diagram for you.
9/30/2019 5:29:37 AM • Philips Audio... • Answered on Sep 30, 2019
Philips Magnavox MRD-250 System Logo
Popular Tags
14 questions posted
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Audio Players & Recorders
Most Popular Question
get fm antenna
  • Audio Players & Recorders
