20 Most Recent Timex T309TT Clock Radio Questions & Answers
How to set time
12/4/2019 2:14:23 AM • Timex T309TT... • Answered on Dec 04, 2019
4answers
I have a Zenith ZG120M alarm clock radio. I can't set it.
Here is how I set my ZENITH ZG120M radio alarm clock.
1) PRESS AND HOLD DOWN the HOUR BUTTON and then PRESS the TIME BUTTON to set the correct hour.
2) PRESS AND HOLD DOWN the MINUTE BUTTON and then PRESS the TIME BUTTON to set the correct minute.
To Set The Wake Up Time
1) PRESS and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the HOUR BUTTON to set the desired hour.
2) Press and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the MINUTE BUTTON to set the desired minute.
There are two light indicators that light up on the left side of the LED display...the top light indicator will come
on once the time turns to PM. The bottom light indicates the alarm is set.
1/21/2016 4:06:18 AM • Timex T309TT... • Answered on Jan 21, 2016
2answers
Display light not working. can't see time at night
From the manual: This alarm clock radio features an adjustable display backlight, with dim, medium, and bright settings. To select a backlight setting, press the Snooze/Dimmer Bar until the desired brightness is reached.
1/12/2015 12:12:04 AM • Timex T309TT... • Answered on Jan 12, 2015
3answers
Need the manual for the timex t309t
You can download and print your manual here:
http://www.timexaudio.com/pdf/T309_IB57517_39.pdf
7/21/2014 7:36:05 PM • Timex T309TT... • Answered on Jul 21, 2014
How to set watch?
On the basis of your sentence "How to set watch", I'm not certain if your asking "how to set the time" or "how to use the memory buttons. Rather than speculate, it might be beter if I directed you to download an owner's manual and read what each button & function does. Here's a link to the manual: data manualslib com
5/28/2014 5:26:57 PM • Timex T309TT... • Answered on May 28, 2014
Kleenmaid rangehood
I found the manual for the Timex T 309T here: http://www.manualowl.com/m/Timex/T309TT/Manual/272204
1/20/2014 12:40:45 PM • Timex T309TT... • Answered on Jan 20, 2014
2answers
How to set time on the TIMEX t309t
Hi,Please follow these instructions:Setting the Clock1. Press and hold the 5 Time Set Button until the display begins flashing.2. Press the 10 Reverse or 14 Forward Button to set the time. Holding a button for a few seconds will advance or reverse the time rapidly. Set the correct AM/PM time, shown by the PM Indicator on the display.3. After setting the time, press the 15 Enter Button or wait about ten seconds for the unit to beep twice and the display to return to the normal mode.Setting the Calendar1. It is important to set the correct date in order to use the 7-5-2 Alarm settings. Press and hold the 6 Date Set/7-5-2 Button until the display flashes and the year replaces the month/day at the bottom of the display.2. Press the 10 Reverse or 14 Forward Button to set the correct year, and then press the 15 Enter Button. The unit will beep and the display will show the month and day. Again, press the 10 Reverse or 14 Forward Button to set the current date.3. After setting the date, press the 15 Enter Button or wait ten seconds to return to the normal display mode.11_28_2011_12_30_59_pm.jpgI hope I could help.Thanks
1/20/2014 12:38:13 PM • Timex T309TT... • Answered on Jan 20, 2014
Instructions
From the manual: Setting the Clock 1. Press and hold the Time Set Button until the display begins flashing 2. Press the Reverse or Forward Button to set the time. Holding a button for a few seconds will advance or reverse the time rapidly. Set the correct AM/PM time, shown by the PM Indicator on the display 3. After setting the time, press the Enter Button or wait about ten seconds for the unit to beep twice and the display to return to the normal mode Setting the Calendar (It is important to set the correct date in order to use the 7-5-2 Alarm settings) 1. Press and hold the Date Set/7-5-2 Button until the display flashes and the year replaces the month/day at the bottom of the display 2. Press the Reverse or Forward Button to set the correct year, and then press the Enter Button. The unit will beep and the display will show the month and day. Again, press the Reverse or Forward Button to set the current date 3. After setting the date, press the Enter Button or wait ten seconds to return to the normal display mode Setting the AM/FM Radio Alarm 1. Press and hold the Radio Alarm Button until the settings and radio frequency appear on the display. 2. Press the Reverse or Forward Button to set the alarm time. 3. Use the AM/FM Band Button or the Memory Set 1-6 Buttons to select a radio station to wake up to. Adjust the alarm volume using the Volume Thumbwheel 4. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display. 5. After you have programmed the radio alarm, press the Enter Button or wait ten seconds to return to the clock display. The Radio Alarm Indicator will appear on the display, showing that the alarm is set. Setting the Nature Sounds Alarm 1. Press and hold the Sounds Alarm Button until the settings and Nature Sounds Indicator appear 2. Press the Reverse or Forward Button to set the alarm time 3. Use the Nature Sounds Button to select a nature sound to wake to. There is a choice of four sounds: Sound #1: Ocean Surf Sound #2: Forest Spring Sound #3: Rushing Brook Sound #4: Summer Wind 4. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display. 5. After you have programmed the nature sounds alarm, press the Enter Button or wait ten seconds to return to the clock display. The Nature Sounds Alarm Indicator will appear on the display. Setting the Buzzer Alarm 1. Press and hold theBuzzer Alarm Buttonuntil the alarm setting appears on the display. 2. Press the Reverse or Forward Button to set the alarm time. 3. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display. 4. After you have programmed the buzzer alarm, press the Enter Button or wait ten seconds to return to the clock display. The Buzzer Alarm Indicator will appear on the display, showing that the alarm is set.
1/6/2014 12:30:25 AM • Timex T309TT... • Answered on Jan 06, 2014
Clock light not working
Do you picture yourself as someone who could take the clock apart and unsolder the light then solder in a replacement? If not it would probably not be cost effective to pay to have someone repair it.
12/1/2013 1:47:59 AM • Timex T309TT... • Answered on Dec 01, 2013
manual
manual
Timex T309TT Clock Radio Logo
52 questions posted
Top Timex Audio Players & Recorders Experts
Steve
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Timex Audio Players & Recorders
Most Popular Question
need users manual timex t309t nature
  • Audio Players & Recorders
