20 Most Recent Philips CDR765 2-Disc CD Recorder Questions & Answers
CDR 765. Recording side will not recognize disc.
Try to clean laser with cleaning disc.I had the same problem and cleaning disc resolved the problem
3/9/2017 7:27:55 AM • Philips CDR765... • Answered on Mar 09, 2017
2answers
Recording
The No OPC message means that the unit can't record. The laser power calibration for the burner failed the internal test with that disc. Was the disc a blank disc? Make sure that you use a clean CD-R or unfinalized CD-RW. Try a different lot or brand of CD-Rs or CD-RWs. If the problem persists, then the laser on the recorder is damaged. If the unit is under warranty, contact Philips. However, based on the date given on the manual, this may not be worth finding a shop to fix the unit. DVD/CD burners for computers are fairly cheap but I'm not sure of the specs for a replacement CD burner for inside this unit. The manual is available from Philips here: www.p4c.philips.com/files/c/cdr765bk/cdr765bk_dfu_eng.pdf . The trouble-shooting information is on page 21 (page 23 of the PDF). I hope this helps. Cindy Wells
7/14/2015 10:46:16 AM • Philips CDR765... • Answered on Jul 14, 2015
How do i can download the electric circuit of the power supply of the CDR 765 2-disc CD Recorder
si enciende la grabadora pero no lee o no graba lente mal.
7/14/2015 10:41:12 AM • Philips CDR765... • Answered on Jul 14, 2015
2answers
I have a CDR 765
hola la cdr765 de philips es una grabadora de pc 3610 de philips o hp7200, el opc error es la lente esta mal, compra ina grabadora y cambia los 2 circuitos de la mecanica original de la cdr765 y desmonta la 3640/7200 y ponle los circuitos montas y a disfrutar.
11/25/2014 9:26:03 PM • Philips CDR765... • Answered on Nov 25, 2014
It wont record all my cd tracks, its starts
Sounds more like it won't record ANY of your CD tracks. Is there any indication why? Are you sure it has audio coming in? Many CD recorders will automatically stop recording if they sense extended silence.
12/1/2013 7:37:04 PM • Philips CDR765... • Answered on Dec 01, 2013
0answers
NECESITO EL PLANO O DIAGRAMA
la solucion a el manual de esta grabadora esta en retrevo.com/manuals.. ellos tienen infinidad de manuales para toda clase de aparatos electronicos incluyendo grabadoras de cdr..espero tengas suerte en encontrar el manual..suerte
8/26/2013 12:55:56 AM • Philips CDR765... • Answered on Aug 26, 2013
I can't get it to record
Are you using a blank media or a CD, if you put a DVD in it won't record on that. Read the manual that came with the unit.
12/15/2012 11:48:18 AM • Philips CDR765... • Answered on Dec 15, 2012
How do you record
You put blank media in the record side and hit the record button. These CD recorders are not as easy as using a Cassette deck. You need to Finalize the disc before it can be read on a standard CD player.
12/15/2012 11:47:20 AM • Philips CDR765... • Answered on Dec 15, 2012
We put the empty disc,we follow the instructions and we cant record.maybe the lazer has problem
Might be. But before replacing the optical pickup unit, a through check should be done.
4/22/2012 5:44:16 AM • Philips CDR765... • Answered on Apr 22, 2012
No power
Check the power cord first. If it is OK, check the fuse inside the device. There is glass cargtridge type, repalcable fuse, can be located on the main power supply regualtor board.
3/16/2012 1:51:51 PM • Philips CDR765... • Answered on Mar 16, 2012
2answers
Having difficulty locating cd-rw's that
I hope you're looking for CD-RW DIGITAL AUDIO blank media. Try eBay.
7/28/2011 3:38:27 PM • Philips CDR765... • Answered on Jul 28, 2011
Philips CDR765 2-Disc CD Recorder Logo
42 questions posted
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
David Shaub
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Audio Players & Recorders
Most Popular Question
cdr 765
  • Audio Players & Recorders
