20 Most Recent
Philips FWC550 Shelf System Questions & Answers
My radio turns on but
your player is having a power problem. A bad IC is the cause of this.
Take the player to a repairer, so that the bad IC can be replaced.
Good luck.
My radios does not stay on
There is a mechanical problem.... So get it serviced.
but still try by setting out your gadget to factory defaults..........
Power shuts off
The unit is in "protect" mode. Basically a problem is detected in the last output stage of the amplifier section and the unit shuts down to prevent further damage. I suspect that you connected too many speakers to the system. The impedence load was too low for the amp section to handle and one or more output transistors have failed. This should be a straightforward repair for any local repair shop. Figure on $20-$40 for parts plus the local labor rate for the repair. I am not familiar with your specific model, but these shelf units are all similar in design. I will try to locate the service manual for this one to get you more details.
Dan
