20 Most Recent
Vivitar DVR-390H Digital Camera Questions & Answers
I have a vivicam and it didn't come with a chager
I sense that your camera is not actually the DVR-390h in the title. That is an older multi-media device that came with a lithium battery and a charger.
If you bought your camera new and got no charger with it, it may be that your camera uses ordinary AA batteries, which can be rechargeable or just disposable Alkaline cells. You would have got a set of alkaline AAs with the camera, and when these expire, you just put in a fresh set, that you can buy anywhere. DON'T use cheap zinc or "long life" AAs, though. They are not up to the task, and can leak and corrode your camera.
If you want to, you can buy a set (or two sets, to have spares) of rechargeable AA cells. Get high capacity NiMH type, preferably 2300mAH or 2700mAH rated ones. You can often buy these with a charger relatively cheaply. These batteries can last longer, per charge, than alkalines, and will work out cheaper in the long run.
Docking station
Vivitar was purchased by Sakar and they do not support anything that Vivitar used to make or carry any of the products. I suggest looking on ebay to see if anyone is auctioning it. If not, Google it for something like "Vivitar DVR 390H docking station".
But to be honest, it probably is not the docking station. I have had the same problem, as many others have had, that the connector in the camera is the issue. This camera has TONS of design flaws.
Dvr 390h
These cameras are notorious for overheating. The one that I have usually takes alittle while before it overheats, but when it does the screen freezes and i can only turn it off by pulling out the battery. The reason these cameras were only produced for about half a year is because of this problem. There is a major design flaw with the camera. If you look at it closely, you will not see proper ventilation areas. If you have noticed, after using the camera for maybe 10-15 minutes the back of it gets EXTREMELY hot. My best suggestion is to try to keep it away from ANY external heat sources when using it. Also, do not use it for prolonged amounts of time. The only thing I use mine for now is a backup harddrive because of the 20 GB harddrive on it and I don't have to worry about overheating because as soon as I am done uploading files, I turn it off. So if nothing else, you do have a pretty nice backup hard drive. Hope this helps!
I lost my adapter to recharge my camera
You might be able to buy a replacement or universal adapter at your local CircuitCity or Best Buy. If you can find one there, may I suggest that you contact the camera's manufacturer.
I have a Vivitar mini digital camera but no CD to load software. Where can I get software download?
Mostly additional software isn't needed as digital cameras invariably capture and store images in jpeg format that can be downloaded, viewed and stored on any Windows computer and probably most other types.
Connect the camera to a usb port and switch on and the computer should recognise it and provide an onscreen menu. Once connected one of my cameras produces an onscreen menu where I have to select "connect to pc".
An alternative to the above is to remove the memory card from the camera and use a card reader to access the pictures.
The cd supplied with a digital camera is usually photo processing software, the like of which can be downloaded free from many online sources.
