20 Most Recent Vivitar ViviCam 3765 Digital Camera Questions & Answers
no not a vivitar website. it is a driver download for old and out of production drivers. not just for cams but any older computer drivers for network,video,etc. there are free driver download websites but require some searching. best way is to look into a driver update program if old software is installed. I use the free version of driver updates from io bit. http://www.iobit.com/en/index.php
more than just drivers too. cleaners,defragers,and uninstallers. all with free versions. might want to check them out
Vivitar ViviCam... | Answered on May 01, 2017
Firmware only can be installed on a fully functional device. It is wrong to think you could put some firmware into a device, without the special programs the manufactures uses. When a firmware is made available for a camera, it is most of the time put on a memory card. It has a certain name and size. The camera must function for 100%, because the software has not only to recognise the file where the firmware is in, it also must place the software in the flash memory, without an error. For that it only has one chance, of always make sure there is enough power available to transfer and to install the firmware. When things go wrong, you bricked the camera and the only thing you can do is bring it to a certified service centre. Camera's in warranty, will be flashed for free, but out of warranty, it could be they charge you for the job.
Vivitar ViviCam... | Answered on Jan 01, 2015
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Vivitar ViviCam... | Answered on Aug 08, 2012
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Vivitar ViviCam... | Answered on Apr 02, 2011
Take the card out of the camera. There is a tiny plastic switch at the edge of the card. Your daughter must have accidentally put it in the "lock" position to prevent taking photos. Unlock the card and use normally.
Vivitar ViviCam... | Answered on Jan 16, 2011
Consider NOT connecting your camera to your computer.
Vivitar ViviCam... | Answered on Jan 15, 2011
You can't. The 3765 was designed as a camera, storing high-resolution images (and videos) to a memory card. It was not designed to stream live video to another device.
Vivitar ViviCam... | Answered on Nov 24, 2010
It depends on the picture resolution and the size of the memory card.
Normal JPEG 2048 x 1472 : 11.0 - With 16MB built-in memory , Fine JPEG 2496 x 2016 : 19.0 - With 16MB built-in memory , Normal JPEG 2048 x 1376 : 19.0 - With 16MB built-in memory , Fine JPEG 2496 x 2016 : 9.0 - With 16MB built-in memory , Normal JPEG 2048 x 1472 : 9.0 - With 16MB built-in memory , Normal JPEG 2048 x 1376 : 35.0 - With 16MB built-in memory , Fine JPEG 1024 x 736 , Fine JPEG 1024 x 736
The capacity of various memory cards will be similar to the above ratios.
I hope this helps.
Vivitar ViviCam... | Answered on Jul 04, 2010
The best I can do for you is give you the number for vivitar support. I have looked to see if I could find the installation files and no luck. I am pretty sure that Vivitar can help you. Best wishes.
Customer Support [email protected] US: 1-800-592-9541 UK: 0-800-917-4831
Vivitar ViviCam... | Answered on Sep 17, 2009
check here, they can get you every Vivitar driver
Vivitar ViviCam... | Answered on Jul 24, 2009
The polarity is correct, but 400mA is not enough. One commercial supply I saw was rated at 2.5A. I even suspect 3v isn't enough as I have tried an external battery pack with D-Cells in it and after a few flash shots it wants new batteries. The camera itself seems to be over-sensitive to "low" voltage and complains about new or freshly charged batteries (see other posts).
There is a problem with these cameras in this battery voltage area. I have asked Vivitar what external voltage to use, but no reply. Good luck! I am sufficiently fed up with this camera that I may try 4.5v external supply and if it blows up, good riddance!
Vivitar ViviCam... | Answered on Jun 19, 2009
There will be a setting where you tell it to add the time and date by choosing ON. This is different to where you set the time and date. Generally it is within your menu and may be with ""setup menu"" and called "date stamp". If you set this to "on" it should do the trick.
Vivitar ViviCam... | Answered on Jun 13, 2009
I did not get any help.
Please inform me as to how I am to make the call, the live assistance I paid for.
Other wise please refund my money.
Abbey
Vivitar ViviCam... | Answered on Jul 17, 2008
My problem is this; i changed the battery after i had signal that battery should be changed. I changed the batteries with new one but when i press the on/off button, the camera will turn on.
I put in new batteries again and is still the same problem.
Vivitar ViviCam... | Answered on Jun 22, 2008
Vivitar ViviCam 3765 Digital Camera Logo
27 questions posted
Top Vivitar Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
View Most Popular
ViviCam Vivitar
  • ViviCam Vivitar
Most Popular Question
firmware reinstalled in vivicam 3765
  • Cameras
