20 Most Recent
Vivitar ViviCam 3935 Digital Camera Questions & Answers
My vivitar experience image manager wont install
Consider NOT using the Vivitar software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
Blocked driver
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or
Picasa.
I have got a new computer and even though I have
Picasa.
Need the driver for Vivitar
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Card locked
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
My camera won't turn on either....
Either the lens is out of alignment, or the CCD or worse has gone defective. Either way it sounds like it may be worth it to just purchase a new camera. You do always have the option of repair as well.
Thanks,
Lee
Vivitar 3935
solution----purchased a new camera 1!!!! compatible with bdy Vista!!!
Vista
I used the win 98 driver on cd for vista or it will not open the drive had to reboot after to see drive but it does work with vista.
Memory card locked
Check the side of the memory card
there is a lock on it.
Hope this helps
Regards
Richard.
Vivitar 3945 camera
You wont quite simply get it fixed.
Try the Vivitar Technical Support-tell them when purchased -
Dont tell them you dropped it
See what happens
Otherwise New camera
There are no Fix options.
My 3935 keeps erasing memory cards...
i know it's not solving your problem, but at least it stop from happening again...
You can protect images/video clips from being accidentally erased using the protect function in the Playback menu... see also:
http://www.fixya.com/BrowseManual.aspx?prdid=218406&mpgid=843814&hlt=erase
