20 Most Recent Sanyo DS35510 35" TV Questions & Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sanyo DS35510... | Answered on Jun 25, 2017
Try repeating initial set up.
Sanyo DS35510... | Answered on Sep 09, 2016
Check the connection to its Ariel for firmness. If it is OK, check and replace its tuner. It is faulty.
Sanyo DS35510... | Answered on Jul 15, 2014
Check this link to download the user manual in PDF. It has all details. See its specification page.
Sanyo TV Manuals
Sanyo DS35510... | Answered on Feb 08, 2014
The tv FBT-(Flyback transformer) high voltage is dead,that why u hearing a buzzing sound.The FBT is the big black block of plastic with a red wire with a cap that hook up to the CRT-(tv tube).
Sanyo DS35510... | Answered on Mar 29, 2011
You need to change the input source to TV. You can do this with the original remote by pressing Input. (Unless the unit is in VCR mode then press TV and then Input). There is no Input button on this TV as far as I know.
If you do not have the original remote, you need a remote that matches this function. An exact replacement remote is available here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=DS35510&uuid=12925568663700 . Some universal remotes will have this feature but usually not the cheapest ones. Make sure the universal remote was programmed at least 6 months after the TV was released. The exception: the universal remotes that can be programmed via a USB connection to your computer.
I hope this helps.
Sanyo DS35510... | Answered on Dec 17, 2010
i would say it might be an indication of the screen going bad or the controls on the inside of the tv need to be adjusted.good luck
Sanyo DS35510... | Answered on Nov 24, 2010
Maybe faulty power switch or its blown a fuse or the powwer supply inside the TV is kaput.
If its out of warranty get in touch with a reputable TV mechanic and ask them to come and repair it. It might be good to get a ballpark figure on how much it's going to cost.
Good Luck
Sanyo DS35510... | Answered on Mar 21, 2010
I'm afraid, you need TV remote to press display / info button to disappear "video" display in screen.
Please look that TV remote in neighbors / friends to press that button.
Thanks.
Sanyo DS35510... | Answered on Jun 17, 2009
sanyo DS35520 no power transistor Q605 short decription a608n replace with transistor 608 no leters
Sanyo DS35510... | Answered on Jun 15, 2009
You may have a malfunctioning audio output IC. I would suggest checking the input to the IC and seeing if you have an audio signal at the input. If so then the output IC is defective, if not continue checking the stages of audio going back from the output IC.
In addition check your speaker connections, and internal cabling.
This can cause this problem also.
Thank you
Shuttle83
http://www.electron-age-technologies-llc.com
Sanyo DS35510... | Answered on Apr 06, 2009
http://www.replacementremotes.com/store/prodthumbs.cfm?categoryid=267&keyword=DS35510+&x=75&y=18
That remote should work.
Sanyo DS35510... | Answered on Feb 05, 2009
Hi and welcome to FixYa,
Offhand, on most TVs, your described issue indicates that the Pump Up capacitor has slowly leaked and/or nearing end of life (dried up). This capacitor would be located very very near the Vertical Deflection IC and would be the biggest of the bunch of capacitor within that immediate area.
Good luck and Thank you for using FixYa.
Sanyo DS35510... | Answered on Jan 04, 2009
Offhand, if the previous system/connection works then we should leave that as it is. Coax-Sat Receiver-Coax-DVD Recorder-TV and TV should be Channel 3 (or 4).
On the new Sat Receiver, coax from LNB/Dish to Sat Receiver, yellow, red & white to TV. TV should be set to Video 1 or A/V or Video. There should be no snow, rather if no reception, it should be blue indicating video has muted in the absence of a good signal.
Mine did this about 6 months ago took to tv repair. The video board was loose they said they just pushed it back down and mine has worked fine every since.
Sanyo DS35510... | Answered on Oct 10, 2008
the red gun or the video driver ic went bad, nothing you can do alone, if the red gun went bad you will need to replace the crt wich is too expensive
Jose
Sanyo DS35510... | Answered on Aug 13, 2008
Hi there!
I think you may have a problem on the tuner module. If using scart connector in your country, check the cable itself or replace, otherwise loose connections on the inside of the unit or a circuit fault. Try the cable first then a repair technician. Good Luck,JUS004
Sanyo DS35510... | Answered on Mar 05, 2008
Sanyo DS35510 35" TV Logo
64 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
turn back
  • Televison & Video
