20 Most Recent Sanyo AVM-2509S TV Questions & Answers
Can hook up a dvd to a sayno avm-2509s tv
Yes. Refer its user manual for details. google.com/+GopakumarGopalan
7/15/2014 6:53:48 AM • Sanyo AVM-2509S... • Answered on Jul 15, 2014
Schematic diagram for sanyo tv AVM-2979P
Only two choices here aside from Google the model number with "service manual" is to contact Sanyo or look to see if the set is covered by a Howard W. Sams photofact manual.
5/15/2012 8:12:57 PM • Sanyo AVM-2509S... • Answered on May 15, 2012
0answers
Tv Turns on for a second, and then turns off?
Your power source seems to be the problem, the part is located inside the tv, replace that, and you can start watching tv again!
7/19/2010 12:39:21 AM • Sanyo AVM-2509S... • Answered on Jul 19, 2010
2answers
I have a sanyo tv. Slightly older. Not hi-def or New
Hi:
This may be due to the possiblity that the you are on the wrong input source, If you watch HD Channels then the input source would either be componet or HDMI input. Try changing the input source of the television with the TV's remote until you see the Channels again. IF you are not watching HDTV then the television is on the wrong reception channel for the Direct TV's box. Try channel 4 or 3 or even 73.
5/6/2010 6:44:01 AM • Sanyo AVM-2509S... • Answered on May 06, 2010
Sanyo DS25630 25" TV
you must have changed the mode while connecting play station.that might have disturb. any loose contact from outside only. in my opinion your tv might be ok.
2/13/2008 2:34:53 AM • Sanyo AVM-2509S... • Answered on Feb 13, 2008
My tv is fine last time i checked, now it wont turn on. ITS BLUGGED IN AND EVERYTHING!
You have an indication the unit was dropped ,if that is the case the unit might have a broken circuit board,a crack on the very edge of the circuit board or somewhere in the center where the heavy components are.If you are familiar with tv service you can likely find where is broken but repairing that section is what becomes difficult,sometimes the traces are very thin and it can not be repaired.If you are not too familiar with tv service you should seek the help of a professional only for an estimate. Let Us know if you need more information.
12/6/2006 3:35:47 PM • Sanyo AVM-2509S... • Answered on Dec 06, 2006
Fixing a 42 Sanyo tv, model# DP42D23
Thanks for the good article. I hope to see you with a better article than the one I am writing now. Thank you again :)
11/20/2022 7:21:14 PM • Sanyo Televison... • Answered on Nov 20, 2022
I have a white screen on my sanyo tv
Try unplugging your TV for about 10 minutes and also hold the power button on the TV for about one minute and then plug your TV back in again and turn it on to see if the white screen is still showing up again. It could be the capacitors inside of the TV have gone bad or the powerboard is not working.Check the cables and the connections to your TV to make sure they are fully connected. Or the TV connections are bad and should be replaced.
11/13/2022 7:27:17 AM • Sanyo Televison... • Answered on Nov 13, 2022
How to fix volume on a Sanyo DP50842 television please?
Buy a new remote for it and stop using the buttons on the television! They are $20. https://www.google.com/search?q=sanyo+dp50842+remote+replacement .
11/12/2022 3:05:25 AM • Sanyo Televison... • Answered on Nov 12, 2022
2answers
I have A Sanyo DP26746 TV with what looks like a burnt mark smudge rite in the middle of the screen the size of a golf ball, any idea what is wrong
Hi, it's sounds like a group of the screens leds have overheated and/or burned out. If you just got the tv, this would be strange. However if you've owned it for years, then this might happen. Please attempt one power cycle and then flip through channels to see if the issue remains. If so, you might need to set a tv diagnostic-appointment with a company like geeksquad/ home depot after attempting a factory reset on the tv. Thank you.
11/11/2022 1:54:06 AM • Sanyo Televison... • Answered on Nov 11, 2022
Sanyo DP32648 - 31.5" LCD TV screen goes black with sound, turns off/on then works for several minutes.
Question edited for full 'make model (what it is)'. Question moved to Sanyo. Could be the power supply, it could be the main board. My advice regarding home television repair, unless our Television Expert Larry comes along. https://www.fixya.com/support/r29790007-repairing_own_television ..
11/4/2022 6:02:31 PM • Sanyo Televison... • Answered on Nov 04, 2022
How can I get rid of pop up showing on the screen from my 32 inch sanyo tv?
go into picture settings and turn it off
10/15/2022 6:00:22 PM • Sanyo Televison... • Answered on Oct 15, 2022
2answers
Sanyo 55 in tv comes on goes back off no channel registered
Is it attached to the aerial/cable socket.? If it is, then the main control board has probably failed.? Changing it out is a fiddly but achievable job, but it's probably only worth it if you can pickup a used replacement part from eBay or similar.? Otherwise a brand new replacement board may be up to $150.?
10/13/2022 10:47:55 PM • Sanyo Televison... • Answered on Oct 13, 2022
Sanyo AVM-2509S TV Logo
13 questions posted
Top Sanyo Televison & Video Experts
Jaime Hernandez
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
schematic diagram sanyo tv avm 2979p
  • Televison & Video
