20 Most Recent Nutrifaster Ruby 2000 Juicer Questions & Answers
Nutrifaster N450 hex nut stuck
Your unit is a Nutrifaster not a Ruby juicer tray again their website of Nutrifaster in Seattle USA...good luck
8/1/2013 5:41:31 AM • Nutrifaster Ruby... • Answered on Aug 01, 2013
I have a Ruby 2000
Short in the wiring of the motor or defective switch or [email protected]
8/1/2013 5:36:53 AM • Nutrifaster Ruby... • Answered on Aug 01, 2013
2answers
Bearing noise
Why don't you contact Nutrifaster as see if they can assist?
8/1/2013 5:34:48 AM • Nutrifaster Ruby... • Answered on Aug 01, 2013
2answers
Where can I buy a basket strainer for the Ruby 2000?
http://www.rubymfg.com/
8/1/2013 5:32:05 AM • Nutrifaster Ruby... • Answered on Aug 01, 2013
Broken side clip on cover
The main problem is that the CLIP needs to be adjusted in order to have the correct pressure adjustment the lever clip should be at a 45 degrees level once is clipped at the bottom anchorage it will be OK to much pressure will brake the securing pins of the unit [email protected]
8/1/2013 5:27:48 AM • Nutrifaster Ruby... • Answered on Aug 01, 2013
Need replacement part, the cutter blade
call 02-97292011 for parts
8/1/2013 5:12:58 AM • Nutrifaster Ruby... • Answered on Aug 01, 2013
What is the difference between the Ruby 2000 and Nutrifaster N350? Were they once produced by the same manufacturer?
If both juicers were purchased in Australia the same the brand name changed in 2001 from Nutrifaster the company to The Ruby Juicer
8/1/2013 5:11:43 AM • Nutrifaster Ruby... • Answered on Aug 01, 2013
Base motor
The Start capacitor in the motor is faulty or the centrifugal switch is worn out [email protected]
8/1/2013 5:08:57 AM • Nutrifaster Ruby... • Answered on Aug 01, 2013
3answers
Have just bought a secondhand Ruby and replaced
Hi Kathy, we had the same problem. You need to soak you basket overnight (every day) in a chlorinated solution/detergent. This will keep your filter basket clean. Also, make sure you rinse out your juicer if you know you are not going to use it much for a few hours as the pulp will dry up and clog your filter. Since adopting we started doing this we haven't had any more problems.
8/1/2013 5:06:33 AM • Nutrifaster Ruby... • Answered on Aug 01, 2013
0answers
I need a Ruby 2000 manual. How can I get it?
Go to the Nutrifaster Australia website and you will find it Click on this link: http://nutrifaster.com.au/juicing-bar-equipment/multifruit-juice-extractors/4:1155/
11/22/2012 11:50:17 PM • Nutrifaster Ruby... • Answered on Nov 22, 2012
0answers
Juicer Jar defective with leakage problem.
Question edited for clarity. Question moved from Computers to Juicers. 3 Duplicates deleted. Refresh the page to see your question. Just contact Amazon and Return it. Log into your Account, click Orders, Find that Item, click Return, it will ask why? Tell them it leaked and set on fire when you used it for the fist time!
Returns and Refunds - Amazon Customer Service
Amazon.ca https://www.amazon.ca > help > customer > display Spotlight · Need to Return Something? · Return items using the Online Returns Centre. · Image linking to self service return video · Returns Items You Ordered.
Return Items You Ordered
Return Items You Ordered · To display your recent orders go to ...
Returns
Returns. If you need to return or replace an item, visit Your ...
Amazon Refund Timelines
We typically process returns within two weeks after the carrier ...
Track Your Return
Track Your Return · Go to Your Orders. · Select View Return ... ..
12/12/2023 4:35:05 AM • Juicers • Answered on Dec 12, 2023
I have a singer juice giant model 774 and I cannot
General instructions: clean the basket-filter-screening of your Singer Juice Giant Model 774: First, unplug the juicer from the power source and disassemble it. Remove the pulp container and the juice jug. Locate the basket-filter-screening and gently twist it counterclockwise to remove it from the juicer. Rinse the basket-filter-screening under running water to remove any pulp or debris. Use a soft-bristled brush to scrub away any remaining residue. Rinse the basket-filter-screening again and dry it with a clean towel. Reassemble the juicer. If you need more detailed instructions, you can refer to the manual for your product
10/31/2023 4:30:58 AM • Juicers • Answered on Oct 31, 2023
Jack LaLanne Juicer. The center screen adaptor doe not loosen and caused motor to lock up.
Questions edited for all the typos and spelling errors.
Contact
Jack LaLanne https://jacklalanne.com > contact Contact. June 8, 2016 admin. Your Name (required). Your Email (required). Subject. Your Message. Sending ... 785 Quintana Rd, Morro Bay, Ca, 93442.
Contact Jack LaLannes Power Juicer Customer Service
Consumer https://jack-lalannes-power-juicer.pissedconsumer.com > ... (973) 575-5400. Sales/ Reservations: (973) 287-5150. Spare Parts Order. Send Message.
Jack Lalanne Power Juicer Customer Service Number
addresscustomerservicecenternumber.com https://addresscustomerservicecenternumber.com > 18... Dec 1, 2016 - The customer service number of Jack Lalanne Power Juicer is : +1 (973) 287-5150. For other related queries, suggestions and feedback, you can ...
10/25/2023 6:11:24 PM • Juicers • Answered on Oct 25, 2023
I have a Magimix 5200 XL Food Processor and the juicer attachment is stuck on the spindle.
Question edited from Australian/NZ 'Megimix', to British 'Magimix', the proper maker name. :>) Plus added '(what it is)'. There is a spring operated probe that goes into the base and is part of the safety interlock. Yours is stuck. Funny, I answered this question yesterday. Remove the lid and spray in some WD40 into the hollow exterior channel part of the bowl. Then operate the spring with a cocktail stick or similar. The spring isn't rising to release the bowl from the base.
4/19/2023 2:19:08 PM • Juicers • Answered on Apr 19, 2023
2answers
Where in the UK can
Your part can be ordered on-line from this website:
https://www.unitycart.com/pjss/parts/parts_classic.asp
11/19/2022 8:25:26 AM • Juicers • Answered on Nov 19, 2022
Omega VSJ843QS Vertical Slow Masticating Juicer. Why is the juice coming out thick with my Omega VSJ843Q?
Question edited for clarity, full 'make model (what it is)'. Question moved from Motorcycles! Juice content of the fruit you are using. Try with Granny Smith apples and make sure they are this season and not last years. Also try the juicer with oranges to prove it is the apples and not the juicer. Also try peeling the apples as a test. The skin can block the strainer. Another trick, run the discarded pulp again. https://www.google.com/search?q=Omega+VSJ843Q ..
11/4/2022 5:06:08 AM • Juicers • Answered on Nov 04, 2022
Need manual for panasonic juice extractor miracle MJ 15
This is a vintage machine and no manual exists. The closest I can find is the MJ-66. There is further confusion because they have a MP3 player with the same model number SJ MJ-15! https://manualzz.com/doc/2127449/panasonic-mj--66pr-juice-extractor https://www.manualslib.com/manual/909071/Panasonic-Sj-Mj15.html https://www.ebay.com/p/1875727370 Close enough? Normally you unlatch the top and lift of the parts inside, macerator and screen, clean inside, wash and replace.
Operating Instructions - Panasonic
https://www.panasonic.hk > usm.ashx > MJ-M176... PDF Operating Instructions. Juicer/Blender (Household Use) ... Please read these instructions carefully and follow safety ... back cover. MJ-M176P / MJ-M171P ...
1/3/2022 11:52:42 PM • Juicers • Answered on Jan 03, 2022
What kind of grease goes into
Edible grease.
12/6/2021 9:59:38 PM • Juicers • Answered on Dec 06, 2021
Nutrifaster Ruby 2000 Juicer Logo
14 questions posted
Top Nutrifaster Juicers Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you a Nutrifaster Juicer Expert? Answer questions, earn points and help others
View Most Popular
Nutrifaster Juicers
  • Nutrifaster Juicers
Most Popular Question
just bought secondhand ruby replaced
  • Juicers
