20 Most Recent Sanyo DVW-7100A DVD Player/VCR Questions & Answers
Dvd stuck
Straighten one end of a Norwegian paper-clip. Put that end into the small hole in the face of the DVD player. Push it in, until you feel resistance. Then, push another 5 mm, to "unlock" the tray. Then, gently pull the drawer the rest of the way open.
2/14/2015 11:47:18 PM • Sanyo DVW-7100A... • Answered on Feb 14, 2015
Disc error
Replace the player -- it will be cheaper than to get a qualified technician to try to repair it.
2/14/2015 11:40:57 PM • Sanyo DVW-7100A... • Answered on Feb 14, 2015
I need a remote controller
Any "Universal" remote control will be able to be programmed for your unit with the codes they provide.
7/14/2014 1:33:11 AM • Sanyo DVW-7100A... • Answered on Jul 14, 2014
0answers
Code issue
Be the first to answer 4/20/2014 4:01:26 AM • Sanyo DVW-7100A... • Posted on Apr 20, 2014Be the first to answer
My DVD seems to be stuck. It will not open so I can put a DVD Video in it.
It's a hardware problem mostly if it is a Benq ...or else.. check the cables ,try changing them.. if still no luck then take it to a hardware repair shop.. it should not cost more than 2-3 $ dollars.. I had one too.. i fixed it .. It costed me around 1 & a half dollar... thank u..
9/8/2012 1:57:18 AM • Sanyo DVW-7100A... • Answered on Sep 08, 2012
Cannot open the drawer to insert a DVD
It is possible that the unit got hit by a small voltage surge and if you leave it unplug from the wall for 40Min., it will reset back to normal.
10/25/2011 3:14:53 AM • Sanyo DVW-7100A... • Answered on Oct 25, 2011
I have Dish network and a Sanyo dvw7100.I moved
Hi my name is Mike Houston of DISH Network and I was readingyour post and see you moved and need a manual to connect your system. I willsend the link to help with the equipment you have, http://www.dishnetwork.com/supportsection/manuals.
5/9/2011 7:12:29 PM • Sanyo DVW-7100A... • Answered on May 09, 2011
I put on the DVD
Hi! If you are not technically proficient, I would recommend using a quality DVD lens cleaner, readily available from many retail stores. In essence, they are just a DVD disc with tiny brushes attached to the playing side, that gently remove surface debris from the lens. If you are brave, you can also take off the cover of the unit (make sure it is not plugged in to the power outlet...duh...!!!), and the exposed lens may be very carefully (...did I say VERY CAREFULLY strongly enough...?!?) cleaned with a cotton swab and alcohol. If you are not able to correct the tracking issues with either or both of these techniques, I would consider buying a new unit. Unfortunately, the repair cost for realigning the lens and/or circuit replacements are generally more than you would want to spend on an older player (unless it is a very expensive unit). Hope some of this helps.
8/26/2010 2:13:15 AM • Sanyo DVW-7100A... • Answered on Aug 26, 2010
My DVD player is locked, the display shows a red
Hi, This sounds like a parental lock issue. Try going into the set up menu and press the down key choosing custom by pressing enter (this is in the user manual page 20 - 22) then go down and select parental. If you know your parental control password code then enter it, if not the reset code is 4737 you will then need to create a new 4 digit code,There are 9 levels to choose from 1 - 8 and all, all being the selection that removes the parental lock. Hope this helps. James
4/22/2010 7:08:23 AM • Sanyo DVW-7100A... • Answered on Apr 22, 2010
Hook up to TV
Get an A/V cord (should be supplied) and match the color of the wires to the color of the jacks on the back of the unit. Plug a set of wires to the OUTPUT section on the back of the combo and the INPUT section on the back of your TV. Then set your TV to Video 1, 2, 3, etc. and you should be set to go. Good luck to you!
For a better explanation consult the combo setup manual.
1/3/2010 2:01:26 AM • Sanyo DVW-7100A... • Answered on Jan 03, 2010
DVD Player/VCR will not power on. What could be
1.check power supplay cable.2.if indicator light is o.k. try start dvd from device, not from rem.control.3.if start, problem is rem.control.
12/5/2009 12:50:28 PM • Sanyo DVW-7100A... • Answered on Dec 05, 2009
Need manual for Sanyo DVD player, DVW 7100 Cinema
You can download the required manual from:
http://www.retrevo.com/support/Sanyo-DVW-7100-DVD-Players-manual/id/311ag904/t/2/
On the page which opens, click on the GET MANUAL button and follow the instructions on the next page to download the manual.
Hope this solves your problem. Thanks.
10/6/2009 5:19:07 PM • Sanyo DVW-7100A... • Answered on Oct 06, 2009
Sanyo dvd/vcr combo
Your universal remote would have seperate selection buttons for VCR and DVD. If you don't have a VCR button, use AUX. Try programming each function seperately - DVD code for your manufactirer on the DVD button and VCR code for your manufacturer on the VCR button.
9/13/2009 3:08:40 AM • Sanyo DVW-7100A... • Answered on Sep 13, 2009
Lost my insructions to the remote
Luckily I found the information on how to set the recorder,,
Thank You for the note,, Calsandab,
2/16/2009 3:39:08 PM • Sanyo DVW-7100A... • Answered on Feb 16, 2009
Televison & Video Logo
40 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
need remote controller
  • Televison & Video
