20 Most Recent Sanyo DWM-390 DVD Player Questions & Answers
3 possible solutions to your problem starting with the easiest:
1. The audio/video cable is bad. It is possible the video side of the cable has a short.
2. Inputs on the back of the TV are mislabeled or aren't matching up with how you are connecting or using the inputs. Feel free to post a picture of the back of the unit with your cords attached and I can tell you for sure.
3. Some dvd players require you to select which video output mode to use. Most of the newer ones come defaulted to hdmi output and might need a menu selection changed to output using component or composite outputs (whichever you are using). Composite will just have the red and white connector for audio and a single yellow connector for video. Component uses the same 2 audio connectors and then red, green, blue conectors for the video.
Let us know more detail and I can help further.
Sanyo DWM-390... | Answered on Jun 14, 2017
You can try the following four digit codes:
0670, 0695, 0873, or 1919.
Sanyo DWM-390... | Answered on Dec 13, 2011
FBI warning on disks are normal and is part of content on dvd, this has nothing to do with the fact that it stops playing (just coincidence) there might be a defect on the disc or scratches
Sanyo DWM-390... | Answered on May 13, 2011
Forgotten the parental control password? there is a way around this. According to the user manual (page 34) for this particular model:
Enter "788444" even if 4 digits "----" appears, then press [ENT]
to clear the current password.
Enter a new password and set the parental lock level again if required.
Note: DVD video discs may or may not respond to the parental lock
settings. Make sure this function works with your DVD video
discs.
You need the original unit's remote to do this. It cannot be done without it.
There is a .pdf of the user manual online.
http://tv.manualsonline.com/manuals/mfg/sanyo/dwm390.html
(It is free to download for personal reference in case you have lost your original copy.)
I hope this helps a tad.
Sanyo DWM-390... | Answered on Mar 08, 2011
Maybe you didn't hook up the red yellow and white wires correctly so retry that.
Sanyo DWM-390... | Answered on Dec 31, 2010
The best bet is to contact Sanyo and to obtain a replacement remote, you can do that either by contacting Sanyo direct or finding their closest authorised repair agent. I don't reccomend getting a universal one as the majority of the time, they do not work. Be prepared to find the remote may be very expensive in some cases. I hope this helps.
Sanyo DWM-390... | Answered on Aug 17, 2010
Forgotten Parental Control password can be bypassed/cleared by entering "788444" even if 4 digits "----" appears, then press ENT to clear the current password. You can then enter a new parental control password.
Sanyo DWM-390... | Answered on Apr 17, 2010
I assume the above problem is on all DVD's. Generally speaking, dialogue soundtrack is located in the Front Center speaker. From your description of the problem I would double check all the wiring to the front center speaker you have connected to your audio system. If there is no front center speaker, check to see how your audio system is set to handle the front center speaker . . . it should be set to "Phantom" or "none". On the other hand you're relying just on your TV speakers and you're not getting any dialog I would change, under the Settings of the DVD player, the Digital Out settings to PCM.
Sanyo DWM-390... | Answered on Jan 20, 2009
While the above problem is not in the manual, I would try pushing and holding down the Open/Close buttton for an extended period to see if the unit will 'unlock' itself.
For the DVM-390 model, I believe this solution should work on the DVM-395 model - Push and hold down the Open/Close button until "UN-LOC" appears on the FL display (or "Disc Tray Unlocked" appears on the TV screen).
For the DVM-390 model, the above problem can be due to the TV Guardian (TVG) mode. I would go to the intial setting options and under Language turn the TVG mode to "Off" and see if that allows the subtitle languages to appear on screen.
You can't, you need a remote. The buttons on the television only give basic operations.
google
make model replacement remote
You will find them on Amazon, eBay and places that ONLY sell replacement remotes. remotes.com is the first link
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk00sR07xjeFUp2sxlLJNlWp1583ouQ%3A1596662372457&ei=ZCIrX9a_G4e6tAbtj7PoBw&q=sanyo+tv+replacement+remote
Sanyo Televison... | Answered 3 days ago
The Sanyo remote control may not have the required codes to control your 2011 Sanyo TV.
Sanyo Televison... | Answered on Jul 16, 2020
You can try using a universal remote control (URC) that has a MENU button.
Sanyo Televison... | Answered on Jul 04, 2020
You need a remote control to adjust menu settings.
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=Sanyo++DP46841+remote+controller&_sacat=0
Sanyo Televison... | Answered on Jul 01, 2020
Sanyo DWM-390 DVD Player Logo
17 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
sanyo dvd player dwm 395 unlock w o
  • Televison & Video
